What is the trace of the second-Rank tensor?
  • Context: Graduate
  • Thread starter Thread starter PRB147
    Tensor Trace
The discussion revolves around the definition and interpretation of the trace of a second-rank tensor, particularly in the context of quantum field theory (QFT) and general relativity. Participants explore whether the trace defined using the metric tensor is merely a definition or if it holds a deeper significance.
  • One participant questions whether the trace of the symmetric second-rank tensor \( S^{\mu\nu} \) defined as \( S = g_{\mu\nu} S^{\mu\nu} \) is a genuine trace or just a definition.
  • Another participant provides a basic definition of the trace of a matrix as the sum of its diagonal elements.
  • A different viewpoint suggests that the trace of \( S^{\mu\nu} \) should be calculated as \( S^{00} + S^{11} + S^{22} + S^{33} \), leading to a modified trace when the metric tensor is considered, resulting in \( S^{00} - S^{11} - S^{22} - S^{33} \).
  • One participant points out a common misunderstanding regarding the correspondence between matrices and tensors, emphasizing that matrices should properly reflect tensors with one index up and one index down.
  • Another participant notes that the inclusion of the metric is necessary to ensure the trace is invariant under generalized rotations.
Participants express differing views on the nature of the trace of the second-rank tensor, with some supporting the conventional definition while others question its implications and the role of the metric tensor. The discussion remains unresolved regarding the deeper significance of the trace definition.
There are limitations in the discussion regarding the assumptions made about the definitions of trace and tensor correspondence, as well as the implications of using the metric tensor in the calculation.
PRB147
In Lorentz group in QFT, why the trace of the symmetric second-Rank tensor [tex]S^{\mu\nu}[/tex] is defined as follows?
[tex]S=g_{\mu\nu}S^{\mu\nu}[/tex].
Is it just a definition or the genuine trace of the second-Rank tensor, and why?
What's the trace of a matrix?
my opinion,The trace of [tex]S^{<br /> \mu\nu}[/tex] should be [tex]S^{<br /> 00}+S^{11}+S^{22}+S^{33}[/tex]
, i.e. the sum over the diagonal elements.
Now the metric tensor [tex]g_{<br /> \mu\nu}[/tex] is taken into account, the trace becomes
[tex]S^{<br /> 00}-S^{11}-S^{22}-S^{33}[/tex].
The problem is that I don't know why
This seems to be a common point of misunderstanding:
Matrices properly correspond to tensors with one index up and one index down.
The fact that books often just write the metric with all up or all down as a matrix is just confusing.
The basic definition of the trace of a matrix is simply the sum of its diagonal elements.
However, in order to make the trace invariant under a generalized rotation, the metric is included.
Thank Cristo, genneth, and clem.
You are correct, it is described in general relativity.
  • · Replies 22 ·
  • · Replies 38 ·
  • · Replies 16 ·
