Choose the Best Fluid for Lifting: Hydraulic vs. Pneumatic
The discussion focuses on the comparison between hydraulic and pneumatic fluids for lifting applications. Hydraulic systems utilize oil, providing greater force due to incompressibility, while pneumatic systems use air, which is compressible and typically expressed in flow rates like SCFM or nL/min. The consensus indicates that hydraulic systems are generally stronger for lifting heavy loads, while pneumatic systems may be suitable for lighter applications. Understanding the properties of fluids, particularly compressibility, is crucial in making an informed choice.
  • Understanding of hydraulic systems and their components
  • Familiarity with pneumatic systems and air pressure principles
  • Knowledge of fluid mechanics, particularly compressibility
  • Basic equations related to flow rates in pneumatic systems (SCFM, nL/min)
  • Research the advantages and disadvantages of hydraulic systems for lifting applications
  • Explore the principles of compressibility in gases versus liquids
  • Learn about specific hydraulic fluids and their properties
  • Investigate pneumatic system design and efficiency in lifting scenarios
Engineers, fluid mechanics students, and professionals involved in designing lifting systems will benefit from this discussion.
tenpai
Right now, I am learning fluids and this question is just asking if i should use either hydraulic or pneumatic fluid for a device that will be able to lift a large fluid.
For pneumatic systems, flow rate is most often expressed as standard cubic feet per minute (SCFM) or normal liters per minute (nL/min)
well i know hydraulic uses oil and pneumatic uses air. I think air is used to lift things up but i think pneumatic is stronger.
What is large fluid? Do you mean just large mass?
Think about compressibility of gases and liquids.
  • · Replies 21 ·
19K
  • · Replies 16 ·
  • · Replies 42 ·
