Could someone please explain this (simple) fact about Taylor expansions?
  • Context: Undergrad
  • Thread starter Thread starter AxiomOfChoice
    Explain Taylor
The discussion revolves around the Taylor expansion of a function L at a point x, specifically addressing the validity of the expansion when a small increment Δx is added. Participants explore the reasoning behind the expansion and the application of derivatives in this context.
  • One participant presents the Taylor expansion of L(x + Δx) and seeks clarification on its validity.
  • Another participant suggests expanding L(u) around u = x and replacing u with x + Δx, indicating this is a standard approach in Taylor series.
  • A later reply questions the validity of directly substituting derivatives from dL/du to dL/dx without considering the chain rule.
  • One participant emphasizes the necessity of using the chain rule to relate dL/du and dL/dx, suggesting that this is a critical step in the argument.
Participants express differing views on the justification for substituting derivatives in the Taylor expansion. There is no consensus on the correct approach to relate the derivatives.
Some assumptions regarding the continuity and differentiability of L may be implicit in the discussion, but these are not explicitly stated. The discussion also does not resolve the mathematical steps involved in applying the chain rule.
AxiomOfChoice
My professor just told me that if [tex]\Delta x[/tex] is small, then we can expand [tex]L(x+\Delta x)[/tex] as follows:
[tex] L(x + \Delta x) = L(x) + \frac{d L}{d x} \Delta x + \frac{1}{2!} \frac{d^2 L}{d x^2} (\Delta x)^2 + \ldots,[/tex]
where each of the derivatives above is evaluated at [tex]x[/tex]. Could someone please explain why this is true? I just can't see it. Thanks.
Let [itex]u= x+ \Delta x[/itex] and expand L(u) in a Taylor's series about the point u= x (NOT [itex]\Delta x[/itex]). Then, in that Taylor's series, replace u by [itex]x+ \Delta x[/itex] so that [itex]u- x= \Delta x[/itex].
Thanks - that's very helpful.
Is it correct to argue that when you evaluate [tex]dL/du[/tex] at [itex]u=x[/itex], you can just replace the "u" in the "du" with an "x" and thereby turn [tex]dL/du[/tex] into [tex]dL/dx[/tex] (and so on and so forth, for higher derivatives of [itex]L[/itex])?
no you can't argue like that. you have to argue through the chain rule. i.e.
[tex]\frac{dL}{dx}=\frac{dL}{du}\frac{du}{dx}[/tex]
now calculate [itex]\frac{du}{dx}[/itex] and discover why dL/du = dL/dx
  • · Replies 25 ·
  • · Replies 16 ·
