| Thread Closed |
Wind power generators |
Share Thread | Thread Tools |
| Feb24-09, 04:59 PM | #1 |
Hi,
I'm trying to build a vertical wind powered turbine system and I'm have trouble finding a small, cheap generator/alternator to use. Does anyone have any suggestions? |
| Feb24-09, 05:08 PM | #2 |
Recognitions:
If you want to build something that works - rather than a science fair project check out these http://www.otherpower.com/
They discuss why you should make your own generator from Volvo wheel hubs and wind your own coils! |
| Feb24-09, 07:59 PM | #3 |
I'm not sure if this is too small, but any 12 volt DC motor from a car should work in reverse as a DC generator. These might be the motors that run the windshield wipers or those that operate the windows. The good thing about them is that they're already perfect for charging a 12 volt battery.
I have one I picked up at a swap meet. It has a large speed reduction through a worm gear. To use it as a generator that worm gear would have to be removed and some other means of gearing it up arrived at. Most vertical axis wind mills are high torque/low speed and you need to arrange your gears or pulleys such that the generator is running at much higher RPMs than the windmill rotor. The slower the rotor, the more torque the wind applies to it. |
| Feb24-09, 08:18 PM | #4 |
Define "small" and "cheap".
| Feb24-09, 10:53 PM | #5 |
Admin
| Feb25-09, 12:36 AM | #6 |
Small, as in under a foot diameter, cheap as in less than $50 dollars.
1kW or less. nothing extravagant. Its for a small wind turbine to be used for airspeeds of less than 15mph. Thanks! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Wind power generators
| Calculating prop size for wind generators | Classical Physics | 1 | ||
| Explain Why Wind Power Works But Permanent Magnet Power Doesn't | General Physics | 10 | ||
| Percent efficiency of three power generators.. need help | Introductory Physics Homework | 2 | ||
| why a generator slow down with resistive loading? | General Physics | 3 | ||
| Why don't they use Pyromagnetic Generators in nuclear power plants? | Electrical Engineering | 8 | ||
