| Thread Closed |
fundamental frequency of a guitar string |
Share Thread | Thread Tools |
| Feb24-09, 09:32 PM | #1 |
1. The problem is: A guitar string is 78 cm long and has a mass of 3.6 g. The distance from the bridge to the support post is L = 60 cm, and the string is under a tension of 505 N. What is the frequency of the fundamental?
I don't get why it gives me two distances. Which one is L? 2. The equations I've been using havent been working, so this is pretty much my problem. 3. When I plugged values into the equation f= sqrt(T/(m/L)) * 1/(2L), I got the answer of 241.762 Hz |
| Feb24-09, 09:53 PM | #2 |
Recognitions:
I don't know much about this, but I wonder if there is a little trick in the mass.
It looks like you are only using 60 cm of a 78 cm string with mass 3.6g. So the mass you want to use in the formula would be 60/78*3.6 g. I get 465 Hz with that small adjustment, which makes me think you made an error in your calculator work - or I did! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: fundamental frequency of a guitar string
| Fundamental frequency of violin string | Introductory Physics Homework | 5 | ||
| Fundamental frequency of a guitar string | Introductory Physics Homework | 12 | ||
| Fundamental Frequency of a String | Introductory Physics Homework | 1 | ||
| [SOLVED] Change in Tension & Fundamental Frequency of a String | Introductory Physics Homework | 2 | ||
| Fundamental frequency of a guitar string? | Introductory Physics Homework | 1 | ||
