Calculating Electron Mass from Magnetic Field and Potential Difference
  • Thread starter Thread starter invinc1ble
    Physics Physics 12
The discussion revolves around calculating the mass of an electron based on its behavior in a magnetic field and the potential difference it was accelerated through. The problem involves parameters such as magnetic field strength, radius of the electron's path, potential difference, and the charge of the electron.
  • Exploratory, Assumption checking
  • Participants discuss the formula for calculating mass and share their derived results. There is a question regarding the accuracy of the magnetic field value and whether the problem was copied correctly.
Some participants have confirmed their calculations match, while others express doubt about the initial parameters provided. The conversation is ongoing, with participants seeking clarification on the problem setup.
There is a mention of potential confusion regarding the notation used for the magnetic field strength, and participants are verifying the accuracy of the values given in the problem.
invinc1ble
I don't know if this is the place to post this, but This is a simple Grade 12 Physics question that I have been working on for about half an hour now.
For those who don't normally use this notation,
2E10 = 2X10^10.
2E-2 = 2X10^-2
"A magnetic field of 3.4E-3T deflects electrons into a circular path of radius .014m. The electorns have been accelerated through a potential differenc eof 250V. If the charge of an electron is 1.6E-19C, what is the mass of the electron?"
I have done it three times, and I keep getting 7.25E-31Kg when in actuality, a real electron is 9.11E-31Kg
Do you really mean 3,400 tesla? I doubt it.
- Warren
sorry.. i'd make that 3.4E-3T
(.0034)
I did this question from a worksheet, and we both got identical answers.
If you have the same answer that my friend and I do, then chances are it is correct.
Thanks for your help!
  • · Replies 44 ·
12K
12K
