How Do You Calculate the Height of Oil in a U-Tube?
  • Thread starter Thread starter superjen
    Height Oil
The discussion focuses on calculating the height of oil in a U-tube with a circular diameter of 5.60 mm after adding 4.00 milliliters of oil. The oil level rises 6.8 mm above the water level in the right-hand side of the tube. To solve this, participants suggest converting the tube's diameter into milliliters of volume to determine the height corresponding to 1 milliliter. Visual aids, such as diagrams, are recommended to clarify the oil and water interface levels.
  • Understanding of fluid mechanics principles
  • Basic knowledge of volume calculations
  • Familiarity with U-tube configurations
  • Ability to interpret diagrams and visual representations
  • Learn about fluid statics and pressure differences in U-tubes
  • Study volume-to-height conversion for cylindrical shapes
  • Explore the concept of hydrostatic equilibrium
  • Practice drawing and interpreting fluid level diagrams
Students in physics or engineering, educators teaching fluid mechanics, and anyone involved in practical applications of fluid dynamics.
superjen
A U-tube of circular diameter 5.60 mm initally contain just water. If 4.00 milliliters(cm^3) of oil is added to the left hand side of the tube the level of the oil is 6.8 mm higher than the level of the water in the right hand side of the tube. Determine the height of the oil.
i'd give some help, but I'm actually clueless on how to start this.
First start by converting the diameter of the inner tubing (which they give) to milli-liters of volume which is how much oil they add. i.e how many mm of height is 1 milliliter of volume.
Then draw a picture showing the oil standing higher (and how much below that the oil/water interface is).
