Calculating Focal Length Using Sign Conventions for Lenses
  • Thread starter Thread starter oooride
    Lenses Sign
The discussion focuses on calculating the focal length of a lens using sign conventions, specifically for a scenario involving a virtual image. The distance between the object and its upright image is 20.0 cm, with a magnification of 0.500. The lens is identified as a Double-Concave (diverging) lens based on the positive distance, indicating the image is formed on the same side as the object. The calculations involve using the magnification formula (M = -q/p) and the lens formula (1/p + 1/q = 1/f) to derive the focal length.
  • Understanding of lens types: Double-Convex and Double-Concave lenses
  • Familiarity with sign conventions in optics
  • Knowledge of magnification formulas in optics
  • Ability to apply the lens formula: 1/p + 1/q = 1/f
  • Study the derivation of the lens formula in optics
  • Learn about the characteristics of virtual images in lenses
  • Explore the application of sign conventions in optical calculations
  • Practice problems involving magnification and focal length calculations
Students studying optics, physics educators, and anyone interested in understanding lens behavior and calculations related to focal length and magnification.
oooride
Okay for the most part I understand the concepts involved but I'm having some trouble with this question.
The distance between an object and its upright image is 20.0 cm. If the magnification is 0.500, what is the focal length of the lens that is being used to form the image?
Now first I understand since this is an upright image formed (virtual) by the lens, that it is either a Double-Convex (converging) lens with the object between the first focal point (F_1) and the front side of the lens, or it is a Double-Concave (diverging) lens with the object placed anywhere on the front side of the lens.
My guess is that it is a Double Concave lens since the question states the distance between the object and the upright image is +20.0 cm. Since it's positive does this mean that the image formed is to the right (closer to the front of the lens than the object is)?
If so, if it was a -20.0 cm would this mean that it is a Double-Convex (converging) lens with the object between F_1 and the front of the lens, and producing a virtual image to the left of the object?
I'm assuming where I'm confused what type of lens it is in order to use the correct "sign conventions". And the object's distance from the focal point is not given..
What I did was:
M = -q/p
0.500 = -(20.0 cm)/p
p = -(20.0 cm)/0.500
p = -40.0 cm
Also how do I know if 20.0 cm is "p" or "q"? I know that p is the object distance and q is the image distance, but if I have the distance between p and q, how do I know which is which?
Then I used 1/p + 1/q = 1/f to find the focal point.
Any help is greatly appreciated.
Thanks in advance.
let the equations do the work
Here's how to think this through. First off, assume the standard sign conventions, then let the formulas do the work for you. The standard is that a positive p means the object is in front of the lens and a positive q means that the image is on the other side of the lens.
So the first fact, the distance between object and image = 20 cm, can be written as: p + q = 20. (Note: I just assume q is positive--if it's negative, we'll find out.)
The next fact is magnification = .5 (positive because it's a virtual, upright image). So: m = -q/p = 0.5.
Now combine these two equations and solve for p and q. Then find f.
I got the right answer and understand it now.
:biggrin: Thanks!
