next number in a sequence of randomly chosen numbers?
by jframe
Tags: chosen, number, numbers, randomly, sequence
jframe
jframe is offline
#1
Feb25-09, 09:24 PM
P: 5
if one were to randomly choose some numbers, such as the 12 below, is it always possible to determine a pattern and figure out the next number? or is this only possible if we are lucky enough to randomly choose numbers that fit a pattern (for example, if we randomly chose the numbers 1 2 3 4 5 6 7 8 9 10 11 12)
2 6 9 23 17 36 22 24 26 32 41 43 ?
what is the next number in the above sequence?
Phys.Org News Partner Mathematics news on Phys.org
Pseudo-mathematics and financial charlatanism
Overcoming structural uncertainty in computer models
A new mathematics for experimental science
CRGreathouse
CRGreathouse is offline
#2
Feb25-09, 09:35 PM
Sci Advisor
HW Helper
P: 3,680
Quote Quote by jframe View Post
42. There are an infinite number of sequences that, apart from some finite chunk at the beginning, have 42 as all members.
qntty
qntty is offline
#3
Feb25-09, 09:37 PM
qntty's Avatar
P: 290
What do you define to be a pattern? For example, if that happens to be the digits in an irrational number, does that count? What if the pattern is 2 6 9 23 17 36 22 24 26 32 41 43 2 6 9 23 17 36 22 24 26 32 41 43 2 6 9 23 17 36 22 24 26 32 41 43 .... etc?
jframe
jframe is offline
#4
Feb25-09, 09:45 PM
P: 5
assuming that the nonsense you are making up is true, it's possible that the non-42 finite chunk at the beginning is larger than 12 numbers
qntty
qntty is offline
#5
Feb25-09, 09:48 PM
qntty's Avatar
P: 290
Yes, so the next number could be 3, what's your point? You have to define something that excludes "nonsense" answers to begin to solve your problem.
jframe
jframe is offline
#6
Feb25-09, 09:51 PM
P: 5
yes, qntty, that would technically count as a pattern, but i'm not content with it
i'd like to find a formula i can use that outputs these numbers, so that i can figure out what the next number is
for example, if i randomly chose the numbers 2 4 6 8 10 12 14 16 18 20 22 24, i could use the formula n*2
is there a formula i can use for 2 6 9 23 17 36 22 24 26 32 41 43?
qntty
qntty is offline
#7
Feb25-09, 09:57 PM
qntty's Avatar
P: 290
A degree n polynomial can be fitted to n+1 points, so yes that's possible. I don't know of any general method to do this for 12 points though.
CRGreathouse
#8
Feb25-09, 09:59 PM
Sci Advisor
HW Helper
P: 3,680
Sure, the one I suggested above can be coded in Pari as
jframe(n)=if(n<1,0,[2,6,9,23,17,36,22,24,26,32,41,43,42][min(n,13)])
Also, there's an 11th-degree polynomial that fits those points exactly.
jframe
jframe is offline
#9
Feb25-09, 10:10 PM
P: 5
is there any way to simplify it and get a less complex formula?
for example, if i randomly chose 1 2 3 4 5 6 7 8 9 10 11 12, i could come up with a less complex formula than an 11th-degree polynomial
i have a feeling the answer to my original question is no. thanks for the help, though
qntty
qntty is offline
#10
Feb25-09, 10:11 PM
qntty's Avatar
P: 290
Not unless the numbers actually are 1,2,3,...,12 because the degree of a polynomial that fits it will be 11 in most cases. To make it unique perhaps you should say that the expression used to describe the nth term must be a polynomial with a minimal degree, otherwise the next term could still be anything.
CRGreathouse
#11
Feb25-09, 10:16 PM
Sci Advisor
HW Helper
P: 3,680
Ah. Now you're getting into the interesting realm of Kolmogorov complexity.
In general, you won't be able to find a way to get a less complex formula to describe your data than the data itself. For some sequences it is possible. The troubles:
  • You must define the environment in which complexity is to be measured (e.g., Pari programs, or closed-form RPN formulas using the following characters: "012n+-*/^!") and the measure of complexity (e.g. characters).
  • Discovering the shortest formula takes exponential time.
DaleSwanson
DaleSwanson is offline
#12
Feb25-09, 11:11 PM
P: 351
If the numbers are truly random then there are no patterns. Patterns and randomness are mutually exclusive. Even when you pick 1 2 3 4 5 6 7 8 9 10 11 12 if the source of the numbers was random then it's no more likely that the next number will be 13 than any other number.
jframe
jframe is offline
#13
Feb25-09, 11:15 PM
P: 5
thanks, cr, that was helpful. i think i might have to surrender to this problem
i'm not picking a random 13th number, dale. i'm looking for the simplest pattern/formula i can find in the randomly chosen 12 numbers to determine the 13th number. if i'm lucky enough to pick 1 2 3 4 5 6 7 8 9 10 11 12, then the simplest formula i can find is f(n)=n
Register to reply
Related Discussions
One more number sequence Brain Teasers 2
next number in a sequence Brain Teasers 9
number sequence General Math 5
Choosing a number randomly? Set Theory, Logic, Probability, Statistics 10
limit of a sequence of numbers 1 to 2 Calculus & Beyond Homework 9
