Simple Design Project: 'Walnut Cracker'
  • Thread starter Thread starter aznkid310
    Design Project
The discussion centers on designing an impact walnut cracker for Yolo County, focusing on specific design criteria such as horizontal operation, a mass sliding on a track accelerated by linear springs, and a mechanism to encase the nut during impact. Key considerations include determining the energy required to crack walnut shells through experimental testing of 10 nuts, which will inform material and geometry selection to prevent fatigue failure. The final deliverable includes working drawings and a comprehensive design project report.
  • Understanding of mechanical design principles
  • Knowledge of linear spring mechanics
  • Familiarity with material fatigue analysis
  • Experience in creating technical drawings
  • Conduct experiments to measure the energy required to crack walnut shells
  • Research linear spring design and its impact on mechanical systems
  • Study material selection criteria to avoid fatigue failure
  • Learn best practices for preparing technical design reports
Mechanical engineers, product designers, and students involved in design projects requiring practical applications of mechanical principles and material science.
aznkid310
Here's what I need to do:
Walnuts are an important cash crop in Yolo County and are popular to consume around the holidays. To give the market a boost, it would be useful to have a device which would facilitate walnut cracking and also be fun to use. Recognizing this need, the objective of this design project is to design an impact walnut cracker which meets the following design criteria:
1. The device must operate in the horizontal position.
2. Impact must be provided by a mass sliding on a track which is accelerated by a linear spring(s).
3. The mass must strike a ‘firing pin’ which slides in a bushing and applies the impact load to the walnut.
4. The nut must be temporarily encased during impact to prevent the nut shell fragments from scattering.
5. The device must be designed to crack an infinite number of walnuts.
Some of the primary design considerations include the slider mass, the sliding distance, and the spring rate. Specifying these quantitatively depends on the energy required to crack a walnut shell. To determine this energy, you will need to devise a simple test to determine the average and standard deviation of the energy required to crack 10 nuts. This data will then be used for the design.
Your assignment is to conceive a device which meets the above criteria, perform the necessary calculations to select both material and geometry so that none of the structural components experiences fatigue failure, generate the working drawings to manufacture the design, and finally to communicate your design through the preparation of a design project report. The contents and format of the report are described in a separate handout.
To get started, I need to determine the energy needed with an experiment. Anyone have any ideas for how I should do this?
This seems to be a homework assignment. As such, it's in the wrong place.
I hate walnuts with a burning passion, but if I have to crack one for the wife I use a hammer.
  • · Replies 26 ·
13K
