Can Work Done Be Negative and Is Potential Energy Ever Negative?
  • Thread starter Thread starter vivekfan
    Sign Work
The discussion clarifies that work done by a force can be either positive or negative, depending on the direction of the force relative to the displacement, as defined by the equation W=Fdcos(theta). When the force and displacement are in the same direction, work is positive; when they are in opposite directions, work is negative. Additionally, potential energy (PE) can indeed be negative, as it is dependent on the reference point chosen for the gravitational field, represented by the equation PE=mgd.
  • Understanding of the work-energy principle
  • Familiarity with the equations W=Fdcos(theta) and PE=mgd
  • Knowledge of vector direction and its impact on calculations
  • Basic grasp of gravitational acceleration, specifically -9.8 m/s²
  • Study the implications of negative work in mechanical systems
  • Explore the concept of reference points in potential energy calculations
  • Learn about the role of cosine in vector mathematics
  • Investigate real-world applications of work and energy principles
Students in physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in physical systems.
vivekfan
Is work done by something always negative and work done on something always positive, or do you determine that by the cos theta portion of the work equation. Also, can potential energy be negative
W=Fdcos theta
PE=mgd
I've been generalizing, and sometimes it makes me come out with the wrong sign, so that's why I need clarification.
I've learned that a negative or a positve merely show direction, and as long as you're consistent throughout the problem, the magnitude of the answer is what matters. For example, the acceleration of gravity is commonly known as -9.8m/s2. However, if you want down to be positive it can be as long as you make up negative. I hope that made sense. :smile:
The work done by a force on an object can be positive or negative depending upon the direction of the force with respect to the displacement. If the force and displacement are in the same direction (more generally, if the cosine of the angle between them is positive), then the work done is positive; if they are in opposite directions (if the cosine is negative), the work done is negative.
Sure.
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 16 ·
