For how long does a measurement collapse a wave function?
The discussion revolves around the concept of wave function collapse in quantum mechanics, particularly focusing on the duration of this collapse and its implications for measurement and superposition. Participants explore theoretical aspects, implications for quantum computing, and the nature of measurements in quantum systems.
  • Some participants propose that there may be a speed limit governing how often measurements can occur, potentially linked to the Planck time unit.
  • Others argue that wave function collapse is irreversible and that once an observable is measured, its value does not change in an undisturbed system.
  • A participant questions whether the principle that we can only know the state of a system at the time of measurement is false, leading to a discussion about the axioms of quantum mechanics.
  • There is a suggestion that the concept of superposition may fail if measurements permanently collapse the wave function for isolated particles, raising questions about the nature of measurement itself.
  • Some participants discuss the implications of measurement on the uncertainty principle, noting that knowing one observable (like position) limits knowledge of its conjugate (like momentum).
  • A participant expresses confusion about the interpretation of Schrödinger's Cat and whether there is a consensus on what constitutes a measurement in quantum mechanics.
  • Another participant emphasizes that apparent deviations from quantum axioms in real systems are due to experimental limitations rather than failures of the axioms themselves.
  • There is a debate about the nature of measurements and whether unique states exist only when measured, with references to the implications for superposition and the Schrödinger's Cat thought experiment.
Participants express multiple competing views regarding the nature of wave function collapse, the implications of measurement, and the interpretation of quantum mechanics. No consensus is reached on these issues.
Participants acknowledge limitations in their understanding and the complexities of defining measurements in quantum mechanics. The discussion highlights the dependence on idealized systems and the challenges of interpreting quantum phenomena in real-world scenarios.
Ivan Seeking
Staff Emeritus
I assume that some speed limit must exist that limits how often we can measure something - if is exists, perhaps the Plank time unit governs this? Do we know this answer? Does this relate to the speed of quantum computers?
Wave function collapse is irreversible:
The value of an observable once measured will not change in a system that remains otherwise undisturbed, and the fact that measured values of the same observable of a system that was disturbed in between measurements will not in general agree is not the result of some restorative process directly inverse to the initial collapse.
Obviously, insulating quantum computers from disturbances that would collapse the wavefunction carrying out some given computation is key.
Of course, limits on how quickly information may be gathered is limited by causality, and the basic unit and meaning of information may ultimately be tied to physics at the Planck scale.
Interesting. I thought it a basic principle of QM that we can only know that state of a system at the time of the measurement and immediately thereafter. After this, the state of the system cannot be known. This statement is false?
According to what the axioms of QM actually say, yep.
I was checking an old textbook and perhaps I confused the idea of random states with perturbed states? The language is clear that a measurement only tells us about the state of the system at the time of the measurement. I guess this emphasis is motivated by the idea that in real experiments, other things will affect the state of the system?
I do see what you mean though. The II postulate [in my text] does state that a measurement of observable A, yielding value a, leaves the system in the state φ. Conservation laws would seem to do the rest.
Still, it does seem that no truly isolated system can exist. Are we discussing an idealized system that cannot exist?
You would be correct to understand that in measurement,there is a optimum distance, an optimum place, and an optimum Time for a single event to occur. If for instance you viewed an event with an energy that is comparably 'slower', it is the TIME factor that changes, the distance between you and the event does not change.
Watching a video in slow motion, you are receiving he same amount of information, at a 'reduced' rate over an 'extended' time.
Yes: Whatever "apparent" deviation from these axioms we've seen in real systems have always been attributable to our inability to perform ideal experiments rather than to a failure of the axioms themselves.
Gees. I read your answer and thought, great, we're done. But something has been nagging me and I finally realized what. Doesn't a fundamental argument exist that unique states only exist when measured? This is what I kept thinking was the motivation for the language of my old QM text. I am sure that I have heard this used as an escape clause for various paradoxes…say for example when we talk about the energy in a field. I will try to explain the violation of concepts that I am alluding to here.
Doesn’t the whole idea of superposition fail if any measurement permanently collapses the wave function for an isolated wave/particle? In fact, if we do consider one wave/particle thingy, and if we assume that it exists as in a superposition of eigenstates, then we must assume that nothing else has ever “measured” the thing. Otherwise, it would seem that we are asserting a solution to Schrödinger’s Cat paradox. That is to say that the concept of superposition only references populations of particles. However I am quite sure that no consensus exists as to what constitutes a measurement, so we can’t know if a thing has been measured. Also, I was not aware that any consensus exists as to the proper interpretation of the Schrödinger’s Cat paradox. So, are you speaking from a particular school of thought, or am I again misunderstanding the basics of QM?
You are mis-interpreting the whole of shroedingers cat?..the cat is representative of a standing wave, It's inside of a box! You are external, the box forms a junction of where your observational limits are defined, and it works both ways, the cat inside cannot see you unless the box is removed, collapsed.
You cannot isolate the cat from the box, yourself from seeing the cat without the box, its the events that are always extended, there are always distructive obstacles in line's of sight when trying to isolate anything, even a single particle!
I understand this.
Sorry, I don't follow your point. I suspect that you are misunderstanding my comments...I'm not sure. Can you tell me what I am saying that motivates your comments?
Originally posted by Ivan Seeking Doesn?t the whole idea of superposition fail if any measurement permanently collapses the wave function for an isolated wave/particle?
A collapsed wave function is still a wave function, since measurement of an observable must by the uncertainty principle leave us with a quantum superposition of all possible values of it's conjugate, i.e. if we know position we don't know momentum.
Jeff, thanks. You have helped to clear up twenty years of confusion. :smile: I will stew on this awhile but I think you hit bullseye.
I am curious about your views on a statement that comes from the Quantum Cosmologists: When I look at a gauge, I don't collapse its wave function, instead I jump into a superposition of eigenstates. As I understand the reasoning, if we can collapse any wave function, then we can infer that we should be able to collapse the wave function of the universe; which it seems that we can't. So, to collapse any wave function is to create a paradox.
Edit: Also, how do you feel about live-dead cats? Do you feel that a single qm entity can exist in a true superposition of states, or do you think this only applies to large populations of particles?
There are quite a few experiments that I think show individual particles are superpositions of states. For instance, the double-slit experiment with individual electrons shows the same interference pattern after enough electrons have been put through it one at a time as a full electron beam; also the work of Abner Shimony and others attempting to resolve the EPR paradox using Bell's theorem has this interpretation in my view. And there are some polarization experiments with individual photons going through multiple polarizers.
Great posts. Physics Forums rules!
  • · Replies 59 ·
  • · Replies 32 ·
  • · Replies 71 ·
9K
