Calculating Orbital Velocity for a Satellite Orbiting Earth
The orbital velocity required for a satellite to maintain a Low Earth Orbit (LEO) at an altitude of 346.9 km is calculated using the formula v = √(Gm_E/r_E). With G as the gravitational constant (6.67 x 10^-11), the mass of Earth (m_E = 5.98 x 10^24 kg), and the radius of Earth (r = 6.38 x 10^6 meters), the resulting velocity is approximately 7,700.27 m/s. However, this value is overly precise given the significant figures of the constants used, and it is more appropriate to express this velocity as approximately 7.7 km/s. Additionally, the discussion highlights that orbits are not perfectly circular, particularly in low-Earth orbit.
  • Understanding of gravitational physics, specifically Newton's law of universal gravitation.
  • Familiarity with the concept of orbital mechanics and satellite dynamics.
  • Knowledge of significant figures and precision in scientific calculations.
  • Basic mathematical skills for manipulating equations and performing square root calculations.
  • Research the implications of orbital eccentricity on satellite trajectories.
  • Learn about the differences between circular and elliptical orbits in satellite dynamics.
  • Explore the role of thrust and velocity in rocket launches to achieve LEO.
  • Study the effects of atmospheric drag on satellites in low-Earth orbit.
Aerospace engineers, physics students, satellite operators, and anyone interested in the mechanics of satellite orbits and rocket launches.
.:Endeavour:.
Can you find the orbital velocity of a planet which a satellite has to obtain in order to revolve around the planet with this formula:
v = [tex]\sqrt{\frac{Gm_E}{r_E}}[/tex]
G = gravitational constant 6.67*10-11
mE = Mass of a planet
rE = the radius of the orbit
rE = h + r
h = height of the orbit
r = the radius of a plant from the center of the planet to its surface
Lets see, if you want to find the orbital velocity that a satellite has to get in order to orbit the Earth in Low Earth Orbit (346.9 km).
mE = 5.98*1024 kg
rE = h + r
h = 346,900 meters (346.9 km)
r = 6.38*106 meters
v = [tex]\sqrt{\frac{(6.67*10^-^1^1)(5.98*10^2^4 kg))}{6,726,900}}[/tex]
v = 7,700.27 m/s
In order to obtain an orbit at an altitude of 346.9 km you will need to get a velocity of 7,700.27 m/s. Is this right, if not please correct me. Thank you for your time.
Astronomy news on Phys.org
That is basically correct. To pick a nit: This result, 7,700.27 m/s, has too much precision. You used a three-figure value for both G and for the radius of the Earth. Your result has thusly at most three significant figures, so saying something down to centimeter per seconds is incorrect. This result also ignores that orbits do not have to be circular, or that there is no such thing as a perfectly circular orbit, particularly in low-Earth orbit.
If you had said 7.7 kilometers per second instead of 7,700.27 m/s I wouldn't have picked so many nits.
The velocity is an approximate, but like you said it isn't exact. I agree that the 7,700.27 m/s does look too precise. I was using my book to refer on what the units to use for the velocity
which gave m/s.
For a rocket to reach 7.7 km does it have to reach that velocity in a period of time or not? Because most rockets like the Space Shuttle reach LEO orbit around 8 to 10 minutes. Just kind of curious there.
  • · Replies 18 ·
  • · Replies 86 ·
9K
