Register to reply
How many Newtons of force would kill a person?
by Simfish
Tags: force, kill, newtons, person
Share this thread:
Simfish
#1
Mar2-09, 08:25 AM
PF Gold
Simfish's Avatar
P: 828
So yes, the atmosphere exerts a force of 100,000 newtons per square meter. A person's head, is obviously much less than a square meter (probably 0.15 meters on the side, which roughly translates to Pi*(0.15/2)^2 square meters). Anyways, for this matter this is irrelevant, as we are already in equilibrium with this force and so we're more concerned about extraneous forces. Now, I know this would depend *a lot* on where the force is exerted and how it's exerted. For this, I'm mostly curious about arbitrary falling objects (rather than, say, bullets). How many Newtons of force would it take to have, say, a 50% chance of killing a person? How many would it take to hurt a person?
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
QuantumPion
#2
Mar3-09, 09:36 AM
P: 778
I don't think there is any general answer for this. A bullet doesn't produce a particularly large force, its speed and density allow it to penetrate the body. On the other hand, a large but flexible ball could land on your head and produce a huge force without doing any damage.
timmay
#3
Mar5-09, 07:41 AM
P: 122
It's far too complicated a subject to even begin to estimate a single force, because as you said it depends hugely on where the force is exerted and over what area. But let's look at two situations, a penetrative situation and a blunt impact.
Penetration (or indentation) is hugely dependent on contact area. So the force required to cause penetration or indentation to the same depth will be lower for a sharp knife than a blunt knife. Hence why it requires a lot less effort to cut a tomato with a knife once you've sharpened it. Essentially, the knife needs to create a stress at the interaction with the incident sample that is greater than the cutting strength of the material, which is related to at least compressive strength and fracture toughness.
Blunt trauma injuries can range from the fracture of bones to internal bleeding to brain damage and even stopping the heart. For many of these injuries there are different theories as to causal criteria. Essentially, for brusing and contusion it's a function of applied stress to soft tissues, and for head injuries acceleration (both linear and rotational) are important.
When it comes to impacts, the force that is experienced by your body is determined by a variety of things. The speed of the falling object at impact (relating to rate dependency of the surface being hit), the mass of the falling object (determining the kinetic energy of the object at impact e.g. a 10kg mass falling from 1m has 10 times the kinetic energy of a 1kg mass falling from 1m), and most importantly of all the deformation characteristics of the surface being hit, because in the case of an impact, the peak force experienced by your body is related to how the object is slowed down to rest. After that, you have to consider the area over which it's acting again in a similar way to the penetration example.
Vanadium 50
#4
Mar5-09, 10:13 AM
Mentor
Vanadium 50's Avatar
P: 16,385
QuantumPion touches on what is the key fact - damage is not done by force, but rather by the differences in force. If every atom in your body and the surrounding environment were suddenly and magically accelerated at a billion gravities, you would be perfectly fine.
D H
#5
Mar5-09, 10:54 AM
Mentor
P: 15,170
Force isn't a particular useful concept when comes to addressing impacts. Impact forces can be extremely high. Even then, the concept of force is a bit fuzzy. You can get very different values just be changing how finely you want to divide time. Force does come into play in the sense that a high impact force is needed for a small object to penetrate skin and bone. To dispel the notion that force is the critical factor, consider the needle yielded by a nurse in a doctors office. The impact force of this needle is incredibly high. Unless the nurse pokes your jugular the needle won't kill. The impact forces in an auto collision are much smaller than the needle, but that car collision may well kill.
Momentum and energy are much important concepts than force. Which of momentum or energy is more important depends on the circumstances. Consider two collisions of some object with a person's head: A purely inelastic collision with a 10 gram bullet traveling at 350 meters per second versus a nearly elastic collision with a 0.43 kg soccer ball traveling at 25 meters per second. The bullet transfers 1225 joules of energy but only 3.5 newton-second of momentum to the head while the soccer ball transfers about 21.5 newton-second of momentum but only a small amount of energy to the head. The bullet can kill while the soccer ball might leave an red mark on the defender's head and give him a bit of a headache. Now bump the soccer ball's speed up some, say to 59 meters per second (the fastest recorded kick). Trying to head that ball away might well kill, but in this case it is the momentum transfer that does the damage rather than energy.
robphy
#6
Mar5-09, 04:15 PM
Sci Advisor
HW Helper
PF Gold
robphy's Avatar
P: 4,137
Quote Quote by D H View Post
Certainly the elapsed time during which momentum or energy is transferred plays a role in this issue.
DaleSpam
#7
Mar5-09, 04:36 PM
Mentor
P: 17,339
Quote Quote by Vanadium 50 View Post
To further emphasize this, these differences in force are called stress. The stress at which a material begins to deform plastically is called the yield stress, and a material's strength is the maximum stress that it can support before failure. A biological material like bone is much stronger in compression (205 MPa) than in shear (65 MPa).
Flyingwing12
#8
Mar26-11, 03:00 PM
P: 41
Is this true that you can accelerate from 0m/s to 30x10^8m/s without killing yourself?
michaelwoodco
#9
Mar26-11, 04:13 PM
P: 28
Quote Quote by Flyingwing12 View Post
He said if every atom in your body were accelerated that fast at the same time. So he is right. But practically no. Top fuel Drag racers for example, experience 5G's of deacceleration. Their retinas detach from their eyes after repeated races.
Also TIME DOES play a huge role. I learned that when I read this:
http://www.motorcyclistonline.com/ge...iew/index.html
You can take 200G's of force to your head for a very very small amount of time.
As noted earlier soft things like balls extend the time of impact. Hard things don't. I think I could use derivatives to explain this. I think I'll ponder this over.
Rap
#10
Mar26-11, 04:42 PM
P: 789
Yes, as long as every bit of your body accelerates at the same rate. If you are in free fall towards a planet, you are accelerating, yet you feel nothing. The more massive the planet, the greater the acceleration. No matter how huge and massive the planet was, you would be fine... until you hit. Then different parts of your body would decelerate at different rates, and you would not be fine.
DrGreg
#11
Mar26-11, 07:57 PM
Sci Advisor
PF Gold
DrGreg's Avatar
P: 1,848
30 108 m/s is ten times the speed of light, so nothing can ever reach that speed.
Rap
#12
Mar26-11, 08:30 PM
P: 789
Quote Quote by DrGreg View Post
LOL - right. The original poster said a billion gravities, which got changed to that. You could survive a billion gravities, as long as every bit of your body was subjected to that same acceleration.
Flyingwing12
#13
Mar29-11, 06:55 PM
P: 41
Quote Quote by Rap View Post
I thought due to relativity we are pretty much, being the size of the universe, being subjected to many gravities.
As well as us moving at 1000 +/- mph.......every atom on this planet is accelerating that much.
And yet when you drive a car. You are accelerating only in the car?
Is there a possibility that a large enough object could strike this planet at 1000+/- mph and stop us?
I assume we would be subjected to a fatal force, that is. everything on this planet
Yeah kind of let my brain flow on this post.....
Pythagorean
#14
Mar29-11, 10:28 PM
PF Gold
Pythagorean's Avatar
P: 4,287
it takes very few Newtons to kill someone with a knife or a needle in the right spot, since pressure is force/area; objects with a very small area of contact can create a tremendous pressure.
RamonaDave
#15
Apr26-11, 10:41 AM
P: 2
As a martial artists I'm intrested in the damage cause by blunt force trauma as this is effectively what is suffered in unarmed combat.
Quote Quote by QuantumPion View Post
This is a misleading statement. Although I'm not a doctor I believe the reason a bullet or knife, or any penetrating object kills is because they severe major blood vessels and organs and fluids seep into body parts that are not suppose to have said fluid. This leads to infections, loss of volume and shock which are the ultimate cause of death. It's not the "force" of the impact nor pressure at the point of impact that cause one to die. As evidence of this I point to people who walk around with bullets or shapnel in them that can't be removed surgically.
In the past I've usually wondered if its the force or energy of the impact. I have discounted momentum as a modality of damage. Since energy and momentum are made up of the same components (ie mass and velocity). If you think about what happens if you are hit with a baseball bat that is swung in an arc. You can move inside the swing and take the impact away from the head of the bat, even a little bit, you can really reduce the damage done to you by the bat. Since the tangential velocity is proportional to the radius of the arc, the momentum of a point halfway down the bat is half of that at the tip (I'm assuming the bat is rotating around the grip end and not being swung by a human arm which will add lenght to the radius). Yet the kinetic energy is 1/4. Thus small changes in velocity yield big changes in damage.
The reason I ask this question (force vs energy) has to do with acceleration. If the force of a strike is the vehicle for damage then the ability to accelerate a weapon and not the velocity at impact is the critical factor. In that case, Bruce Lee's famous 6 inch punch can cause as much damage as the same punch thrown from 24 inches(assume arm's lenght). If, however, energy is important then the punch thrown from 24 inches, although striking with the same force (assuming uniform acceleration throughout the execution of the punch), will strike with a higher velocity (thus have more kinetic energy) and cause more damage.
Lastly I wonder how much "Jerk" plays into this (da/dt).
I'd be interested to hear from an MD on this.
QuantumPion
#16
Apr26-11, 03:33 PM
P: 778
Quote Quote by RamonaDave View Post
How is my statement misleading? What do you think is the cause of death due to any other large force? Hitting concrete at terminal velocity? A brick landing on your head?
Anyways, your question has already been answered in this thread. What kills you is stress (force per unit area).
michaelwoodco
#17
Apr27-11, 04:49 PM
P: 28
I beg to lengthen your answer. A person can die so many ways from all different forces. The one thing I can think of off the top of my head is if you are wearing a very good helmet and get into a crash, the force per unit area is dispersed, and the impact is very small thanks to the collapsing foam liner (think air bags) Yet the person may still die. The brain continues moving inside the skull, and hits it. so the threshold all over the body is different. I can also see other factors playing a role, like the time the force is applied, and impact.
RamonaDave
#18
Apr27-11, 05:39 PM
P: 2
Is this fact or merely speculation??? Have there been studies?? I'd like to see them. You may be correct and the more I think about it the more reasonable the stress, as an answer, becomes to me but I'd like to know if this has been studied? I know in the case of bombs there have been studies and the overpressure or blast wave is the largest contributor to mortality and this would tend to support your theory.
Register to reply
Related Discussions
Little Nellie Newtons Force Problems Introductory Physics Homework 4
Newtons Law on Gravitational Force General Physics 16
How much pressure on the skull to kill a person? Classical Physics 11
Newtons second law force problem Introductory Physics Homework 3
