Finding a Vector Perpendicular to One Vector and Parallel to Another
  • Thread starter Thread starter nns91
    Vector
The discussion revolves around finding a vector \( u \) that is both perpendicular to a given vector \( v \) and parallel to a plane defined by a normal vector \( n \). The problem involves concepts from vector mathematics, specifically the relationships between dot and cross products.
  • Participants explore the relationships between the vectors using dot and cross products. The original poster notes that \( u \) must satisfy conditions related to both \( v \) and \( n \). Some participants suggest considering the cross product as a potential method to find \( u \).
There is an ongoing exploration of the relationships between the vectors, with hints being provided regarding the use of the cross product. Some participants affirm the idea that \( u \) could be expressed as the cross product of \( n \) and \( v \), while also noting that any multiple of this vector would satisfy the conditions.
Participants are working within the constraints of a homework problem, which limits the provision of complete solutions. There is an emphasis on understanding the underlying vector relationships rather than simply arriving at an answer.
nns91
Suppose n is normal to a plane and v is parallel to the plane. Describe how you would find a vector u that is both perpendicular to v and parallel to the plane.
Cross product, dot product
Since u is perpendicular to v, u dot v = 0. U is also parallel to the plane so u will be perpendicular to n, so u dot n=0.
How would I do the rest of it ?
Well, I can't give you the solution, but I will tell you that if I gave you a hint, you'd probably know it. Let's try.
You've used the dot product. Does the cross product help?
You didn't use the cross product. axb is perpendicular to both a and b, right?
Oh so u is basically n cross v ?
Sure. Or any multiple thereof.
