Max and min in several variables
  • Context: Undergrad
  • Thread starter Thread starter Derill03
    Max Variables
The discussion focuses on finding the maximum and minimum values of the function f(x,y) = x² - 2x + y² within a triangular region defined by the vertices (1,0), (1,1), and (0,1). The critical point identified is (1,0), yielding a minimum value of -1. Evaluating the function along the boundaries reveals that the maximum value of 1 occurs at the point (0,1). The analysis confirms that the maximum value is correctly identified through boundary evaluations and critical point analysis.
  • Understanding of multivariable calculus, specifically optimization techniques.
  • Familiarity with the second derivative test for identifying extrema.
  • Knowledge of evaluating functions over defined regions.
  • Ability to analyze piecewise functions along boundaries.
  • Study the method of Lagrange multipliers for constrained optimization.
  • Learn about the implications of the second derivative test in multivariable functions.
  • Explore the concept of critical points in higher dimensions.
  • Investigate graphical methods for visualizing functions in two variables.
Students and professionals in mathematics, particularly those specializing in calculus and optimization, as well as anyone involved in mathematical modeling and analysis of functions in multiple variables.
Derill03
Find max value and min value of f(x,y)= x^2-2x+y^2 for f(x,y) in the region bounded by the triangle with vertices (1,0) (1,1) (0,1)
Im not sure if i did this right, i used second derivative test to find a min at -1, and by plugging in (0,1) i found the max to be 1. But i can only get max value by plugging in (0,1) is there another way to find max that i am missing? And is the way i did this correct?
Ummm...
Well, first we look for relative extrema. Setting
2x - 2 = 0
2y = 0
We get x = 1, y = 0. So (1, 0) is the only critical point.
We must now check the value of the function at the critical point, as well as for points on the triangular boundary. So
f(1,0) = -1.
The first boundary is (1,0) - (1,1) which means x = 1, y between 0 and 1. So
f(1, y) = y - 1 which is maximum at y = 1, so this boundary has a max of 0 at (1,1).
The second boundary is (1,1) - (0,1), which means y = 1, x between 0 and 1. So
f(x,1) = x^2-2x+1 = (x-1)^2 which is maximum at x = 0, so this boundary has a max of 1 at (0, 1).
The third boundary is (0,1) - (1,0), which means y = 1-x, x between 0 and 1. So
f(x,1-x) = x^2-2x+(1-x)^2 = x^2-2x+1 -2x+x^2 = 2x^2-4x+1 which is maximum at x = 0, so this boundary has a max of 1 at (0, 1).
So the candidates are (1,0)=>-1, (1,1)=>0, (0,1)=>1, and (0,1)=>1.
Clearly, (0,1)=>1 is the maximum in the region.
