How to Determine the Block's Position After Applying Force to a Spring?
The problem involves determining the position of a block after applying a force to a spring-block system, given that a specific amount of work is done. The context includes concepts from mechanics, specifically relating to forces, work, and spring potential energy.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the work-energy principle and the spring constant. There are attempts to solve the equation for the final position of the block, with some participants questioning the interpretation of the results, particularly regarding the smaller and larger values of position.
The discussion is ongoing, with various participants sharing their calculations and results. Some have provided specific numerical answers, while others are verifying their methods and questioning the correctness of their results. There is a focus on ensuring that calculations are accurate and that units are properly converted.
Participants are navigating issues related to unit conversions and the interpretation of multiple potential answers. There is a mention of homework constraints that may affect how solutions are approached and presented.
queenspublic
1. Problem
In the figure, we must apply a force of magnitude 63 N to hold the block stationary at x = -2.0 cm. From that position we then slowly move the block so that our force does +4.1 J of work on the spring-block system; the block is then again stationary. What is the block's position (x)? (There are two answers.)
Here's the figure: http://www.webassign.net/hrw/7-11a.gif
? cm (smaller value)
? cm (larger value)
2. Attempt at a solution
+4.1 J = (1/2)k * (xf2 - xi2)
(+63 N)î = -k(-2.0 cm)î k = 3.15 x 103 N/M
xi= -2.0 cm
I got some weird decimal answer which was apparently wrong.
I also don't understand what the smaller and larger value is.
What did you get?
You could move the block in either direction.
0.4
So the smaller value is negative and the larger value is positive, am I right?. I tried -0.4 too. It's wrong.
How did you get the answer of 0.4? (40 cm?) The equation you posted previously looked OK to me. Did you solve it?
Yeah, I got xf = 0.4 cm.
Redo your solution. (And check your answer by plugging back into the original equation and seeing if it works.)
I got 2 this time. Am I suppose to convert that to something?
This is the equation you're solving, right? When you get an answer, plug it back into the equation to verify it.
How are you solving it? Show each step along the way.
I got 2. I'm sure.
Square root of this [4.1 / (1/2)(3.15 x 103) + (-2.0)2]
queenspublic said:
I got 2. I'm sure.
Use standard units: 2.0 cm → 0.02 m.
Ah crap, you're right.
So it's...Square root of this [4.1 / (1/2)(3.15 x 103) + (-2.0 x 10-2)2]
That looks better.
Okay, I get 160.7. Do I have to convert that or something?
Please double-check that answer. (Is 160 m a reasonable answer?)
It's wrong. I got 160.
Let's do it step by step.
A = 4.1 / (1/2)(3.15 x 103) = ?
B = (-2.0 x 10-2)2 = ?
A + B = ?
√(A + B) = ?
A = 25830
B = 4e-4
A + B = 25830.0004
? = 160.7
I tried 161, it's also wrong.
queenspublic said:
A = 25830
Way off. (You're probably multiplying where you should be dividing.)
A = 4.1 / [(1/2)(3.15 x 103)] = ?
o wait a second...you're right
I got .0027. Do I have to convert this?
No conversions needed.
My final answer is .0557, do I have to convert this answer?
I'm getting multiple answers. Second time, I got .0548.
The second one is correct--at least it's the same answer I get. (You're getting multiple answers, most likely, because you are rounding off different parts of your solution.)
Since it's a distance, the answer is in meters. If you want the answer in cm, then you can convert.
