How do I calculate the chance of an atom (ion) losing an electron?
  • Context: Graduate
  • Thread starter Thread starter Shelnutt2
    Electrons
This discussion focuses on calculating the likelihood of an atom or ion losing an electron, particularly in the context of valence electrons and their influence on electrical conductivity in fluids. The user details a method for determining the number of valence electrons in tap water ions and how this relates to calculating amperage using the formula I = q * n * flow. Key insights include the importance of noble-gas electron configurations and the role of ionization in conductivity, as well as the impact of voltage and resistance on charge conduction in solutions.
  • Understanding of valence electrons and their role in atomic structure
  • Familiarity with basic electrochemistry concepts, including conductivity
  • Knowledge of the formula for calculating current (I = q * n * flow)
  • Basic principles of ionization and its effect on electrical properties of solutions
  • Study the principles of ionization in electrolytic solutions as outlined in "Physical Chemistry" by Atkins
  • Learn about the relationship between valence electron configurations and ionization energy
  • Explore models for calculating conductivity in strong and weak electrolytes
  • Investigate the effects of temperature and viscosity on ion mobility in solutions
Researchers, chemists, and electrical engineers interested in the behavior of ions in solutions, as well as anyone looking to understand the principles of electron loss and its implications for electrical conductivity in fluids.
Shelnutt2
So I've read through https://www.physicsforums.com/showthread.php?t=32409" thread on valence electrons but it doesn't really answer my question. I think I am in the right forum, I was debating between here and chemistry but it deals more with atoms. What I want to know is this:
How do I figure out (/calculate) the chance of an atom (ion) losing an electron? Is it based on how many electrons in the valance shell? As it's shell is closer to being filled, or closer to being empty how does it effect the ability to loose an electron?
What I am trying to figure out is how many amps are possible in a flowing fluid.
What I did was I found the total number of valance electrons contained in all of the negative ions in regular tap water. I found out the ions, then I looked up the model, to find out how many valence electrons. From there I divided the weight of the valance electrons by the weight of the entire atom. I then found out what % of weight was valence electrons. Knowing that, I think just multiplied out the % by the mg/l in tap water. I then had several smaller mg/l number which is about equal to the total weight of valence elections per mg/l. From that I divided by the weight of an electron, finding the number of valence electrons per liter. Multiplied by the charge of an electron to get charge / liter. Then I multiplied by my flow in liters / second and I got charge / second or amps. I know the formula for amps is I = q * n * v * A, but v * A = flow, so I can keep that.
Bicarbonate = 113 mg /l *.000134 => .0151 mg/l
Sulfate = 25 mg/l *.000137 => .00342 mg / l
Chloride = 21 mg / l *.000124 => .00260 mg/l
Total valence electrons are 0.0212 mg /l . That is .0212 * 10^-6 kg / l.
Mass of electron is 9.1093818 * 10^-31 . Divide .0212*10^-6 kg/l / 9.1093818 *10^-31 kg = 2.318 * 10^22 electrons/liter. Charge of an electrons is 1.60217646 * 10^-19. q * n = (1.60217646 * 10^-19) * (2.318 * 10^22) = 3,714.63 coulombs/liter
I = q * n * flow = 3,714.63 coulombs/liter* .667 liters/second = 2,477.6 amps.
I have no clue if this is right, or not. Can anyone give me some pointers?
Well, electrons don't just pack their bags and leave, as it were. The electron needs some place to go.
Or to put it more concretely: Imagine a single atom in a vacuum (at low temperature). The chance that an electron will leave, that it'll spontaneously ionize, is more or less zero. The rule you learn is that an atom with a noble-gas electron structure has lower energy, but you need to remember that this is given that it's got other atoms to interact with.
The explanation you get (or I got) in 8th grade Chemistry is that atoms 'strive' to have noble-gas structure, so that elements on the left side of the periodic table will 'want' to lose electrons, and those on the left will 'want' to gain them. As for why that is, I gave a more detailed answer to this in https://www.physicsforums.com/showthread.php?t=293273".
That depends on the voltage of course. And if the voltage is low, the resistance will be limited by the amount of free ions in the liquid that can act as charge carriers. But at higher voltages, the electric potential will ionize the liquid. And if you put in a very big amount of electricity, you're going to be dealing with a plasma (ionized gas).
In general, charge conduction is limited by the number of ions/degree of ionization, and the ease at which they can move through solution, which depends on the properties of the ions, the viscosity, etc. Conductivity is not easily calculated, but various models for ideal cases (strong and weak electrolytes) exist. See a textbook on electrochemistry or physical chemistry.
(Picking up the one I happen to have closest to me at the moment, Atkins, "Physical Chemistry" sec 24.7 "The conductivity of electrolytic solutions")
  • · Replies 0 ·
  • · Replies 22 ·
