Confusion about properties of the del operator
The discussion revolves around the properties of the del operator, particularly in the context of vector calculus. Participants are examining the expression involving the del operator and its application to scalar and vector functions, questioning the validity of certain mathematical identities and interpretations.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are exploring the implications of the del operator acting on scalar versus vector fields, with some expressing confusion about the order of operations and the nature of the del operator itself. There are attempts to clarify the relationship between the del operator and vector functions, as well as the validity of different forms of the equations presented.
The discussion is active, with participants providing insights and clarifications regarding the properties of the del operator. Some participants suggest that both forms of the equation may be correct, while others emphasize the importance of understanding the operator's nature. There is a recognition of differing interpretations and a willingness to explore these further.
Participants are grappling with the definitions and properties of the del operator, including its role as a differential operator and its interactions with scalar and vector fields. There are also references to specific examples and the potential for confusion arising from treating the del operator as a conventional vector.
bcjochim07
I was reading some notes about the del operator, and they make the statement
∇ x (Ua) = U(∇ x a) + (∇U) x a.
However, I disagree with this because it seems to me that in the right hand side of the equation for the second term, the ∇ is operating on a, since a appears after it.
I also worked on some other examples to see if understood the properties of del. For instance, for an arbitrary vector function A and position vector r,
(A dot ∇)r = A and
(A x ∇) dot r = 0.
Both of these examples seem to confirm that ∇ operates on what appears after it (crossed, multiplied, or dotted, but not added or subtracted).
If I expand the right hand side of the above equation, I don't get the left hand side.
I think that the statement should read
∇ x (Ua) = U(∇ x a) + -a x (∇U)
Could somebody help clear my confusion? Thanks.
I would probably write it the way you do, but botth forms are correct.
recall
axb=-bxa
No, this goes back to the order of operations that you learned in arithmetic. Compute what's in the parentheses first, which is the vector [itex]\nabla U[/itex]. Then cross that vector with the vector [itex]\vec{a}[/itex]. In any case it would make no sense for [itex]\nabla[/itex] to act on [itex]\vec{a}[/itex]. Gradients act on scalars, not vectors.
(A dot ∇)r = A and
(A x ∇) dot r = 0.
It does act on [itex]\vec{r}[/itex]. That's because [itex]\vec{A}\cdot\nabla[/itex] and [itex](\vec{A}\times\nabla )\cdot[/itex] are operators, not vectors.
I do get it to work out. So perhaps you should post what you've done so we can examine it.
The del operator is a differential operator, compare the first equation you gave with the ordinary product rule with a(x,y,z) and U(x,y,z) as U is scalar it can be taken to either side of the cross product without affecting the product.
So the equations you have written at the top & bottom are actually equivalent as you have changed the order of the cross product
have a look at this
http://en.wikipedia.org/wiki/Del
Tom,
Thinking back to (A x ∇) dot r = 0.
(A x ∇) is a vector isn't it?
and ∇ is a vector and an operator.
Could you please clarify what you mean? Thanks.
When I expand (∇U) x a, I am doing it like this
(U daz/dy + az dU/dz - U day/dz - ay dU/dz)i + ...
I wouldn't call [itex]\nabla[/itex] a vector. When I say "vector" (in normal 3d space), I mean an element of [itex]\mathbb{R}^3[/itex], which [itex]\nabla[/itex] certainly is not. Rather, [itex]\nabla[/itex] is an operator on [itex]\mathbb{R}^3[/itex]. And so is [itex](\vec{A}\times\nabla )\cdot[/itex].
∇ is a vector operator
it is not a vector
treating it as if it is a vector will lead to much confusion
for example b.(axb)=0
b.(∇xb) need not be 0
I think I'm starting to understand what you are saying. ∇U is the operation on a scalar function which yields a vector function (gradient), so that really can't operate on anything. However, when you dot or cross ∇ with another vector, that does operate on the terms after it. Right?
It is true that the usual ∇ is a right acting operator. Another symbor should be used otherwise. It is very dangerous (as in wrong) to think of say crossing ∇ with a vector, it is much better to think of
∇x()
as three different operators
then there are things like
a.∇()
(ax∇).()
(ax∇)x()
(ax∇)()
20K
