Relativistic speed involving particle decay
The discussion revolves around calculating the direction and speed of a third particle resulting from the decay of a particle of rest mass M0 into three identical particles, each with rest mass m. The initial momentum is zero, leading to the equation p1 + p2 + p3 = 0, where p1 and p2 are derived from the velocities u1 = -4/5c and u2 = -3/5c. The user struggles with breaking down the momentum equations and understanding the squared units in the arctangent calculation, ultimately needing to incorporate the Lorentz factor (gamma) for each particle's momentum.
  • Understanding of relativistic momentum and the Lorentz factor (gamma).
  • Familiarity with vector decomposition in physics.
  • Knowledge of particle decay processes in relativistic physics.
  • Basic proficiency in trigonometric functions and their applications in physics.
  • Study the derivation and application of the Lorentz factor in relativistic momentum calculations.
  • Learn how to decompose vectors in three-dimensional space for momentum analysis.
  • Research particle decay processes and conservation laws in relativistic physics.
  • Explore the use of trigonometric identities in solving physics problems involving angles and velocities.
Students and educators in physics, particularly those focusing on relativistic mechanics, particle physics, and momentum conservation principles.
kpou
A particle of rest mass M0 is at rest in the laboratory when it decays into three identical particles, each of rest mass m. Two of the particles have velocity
u1=-4/5c i(vector)
u2=-3/5c j(vector)
Calculate the direction and speed of particle 3
pf-pi=0
p=(gamma)mu
The starting momentum = 0 since it is at rest, so the momentum of the three particles should add up to 0.
p1=m/(sqrt(1-(-4/5)^2)) -i(vector)
p2=m/(sqrt(1-(-3/5)^2)) -j(vector)
p3=m/(sqrt(1-(v/c)^2)) ij(vector)
the total momentum is p1+p2+p3
I calculated m/.6 -i + m/.8 -j + m/(sqrt(1-v/c)^2)) ij
I'm not sure how to break this up to find v.
I had tried to use u=(sqrt(ux^2+uy^2+uz^2)) but that = 1 for this.
I think to use that equation I need to break down the ij vector of particle 3
To do this it should be atanx=(3/4), but the answer is actually atanx=(9/16) I'm not sure why it's squared. Likely I'm forgetting something very basic that messed up the whole problem.
Main points of interest:
find out i and j vectors of particle 3
find out why the units are squared as in atanx=(9/16) and is that 9/25 (3/5)^2? if so that doesn't compute out using sin 29 = (9/25)/hM/m should be (gamma)1*m+(gamma)2*m+(gamma)3*m since they all have different gammas.
My momentum equations were missing velocity. i only had mass in the numerator. p1=4/3 i(vector) p2=3/4 j(vector)
p3=m (sqrt ((4/3)^2+(3/4)^2))
much thanks to Bekki from yahoo answers :)
  • · Replies 16 ·
