Is My Calculation of Rocket Exhaust Velocity Using N2H4 and Aerozine 50 Correct?
The calculation of rocket exhaust velocity using Nitrogen Tetroxide (N2H4) and Aerozine 50 is confirmed to be correct based on the provided formula and parameters. The exhaust velocity (V_e) is calculated as 2,484.5799 meters per second using the absolute temperature of 3110 Kelvin, a universal gas constant of 8314.5 J/(kmol·K), a molecular mass of 20.24 kg/kmol, and an isentropic expansion factor (k) of 1.2314. The pressures used in the calculation are 1 atm for the exhaust gas and 25 atm for the inlet gas. The sources for the equation and data include Wikipedia and Braeunig's space problem resources.
  • Understanding of rocket propulsion principles
  • Familiarity with thermodynamic equations
  • Knowledge of specific heat capacities (cp and cv)
  • Basic understanding of gas laws and molecular mass
  • Research the impact of varying molecular mass on exhaust velocity calculations
  • Learn about the effects of different propellant combinations on rocket performance
  • Study the principles of isentropic flow in rocket nozzles
  • Explore advanced thermodynamic properties of gases at high temperatures
Aerospace engineers, rocket propulsion specialists, and students studying thermodynamics and fluid dynamics in the context of rocket design will benefit from this discussion.
.:Endeavour:.
Please check my calculations for the exhaust velocity of a rocket that uses Nitrogen Tetroxide (N2H4) & Aerozine 50 as its propelants. This is the formula that I'm using to find out the exhaust velocity:
V_e = \sqrt{{\frac{T*R}{M}}*{\frac{2*k}{k-1}}*[1-(P_e/P)^(^k^-^1^)^/^k] }
Ve = Exhaust velocity at nozzle exit, m/s
T = absolute temperature of inlet gas, K
R = Universal gas law constant = 8314.5 J/(kmol·K)
M = the gas molecular mass, kg/kmol (also known as the molecular weight)
k = cp / cv = isentropic expansion factor
cp = specific heat of the gas at constant pressure
cv = specific heat of the gas at constant volume
Pe = absolute pressure of exhaust gas at nozzle exit, Pa
P = absolute pressure of inlet gas, Pa
T = 3110 Kelvin
R = 8314.5
M = 20.24
k = 1.2314
Pe = Pa = 1 atm
P = 25 atm
[tex] V_e = \sqrt{1,277,573.864 * 10.643 * 0.454}[/tex]
[tex] V_e = \sqrt{6,173,137.26}[/tex]
Ve = 2,484.5799 meters per second
Are this calculations correct or did I make a mistake? I got the equation and most of the data from these two sites: http://en.wikipedia.org/wiki/Rocket_engine_nozzles, http://www.braeunig.us/space/problem.htm#1.10, and http://www.braeunig.us/space/comb-NA.htm.
In spite of the obtuseness of the presented equation the equation is correct; but, I haven't verified the numerical result.
20K
  • · Replies 45 ·
