Points on an Ellipse: Finding Slope of Tangent Line
  • Thread starter Thread starter Emethyst
    Ellipse Points
The discussion revolves around finding the points on the ellipse defined by the equation x² + 4y² = 4 where the slope of the tangent line is 1/2√3. The original poster is working through implicit differentiation and is seeking guidance on how to proceed with solving the resulting equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to differentiate the ellipse equation and set the derivative equal to the given slope to find the points of interest. Some participants suggest forming a system of equations based on the slope condition and the ellipse equation.
Participants are actively engaging with the problem, with some providing guidance on how to set up the equations. There is a recognition that solving the system will likely yield two points, though no explicit consensus on the final solution has been reached.
The original poster mentions being in grade 12 calculus and requests explanations to be kept simple, indicating a potential constraint on the level of complexity in the discussion.
Emethyst
Hello everyone, I am still relatively new to this site, so any mistakes I take full blame for.
My question is: At what point(s) on the ellipse x^2+4y^2=4 is the slope of the tangent line 1/2sqrt3?
I have found the derivative of the equation through implicit differentation (I came out with dy/dx=-2x/8y, if wrong please tell me) and thought I could solve the given equation for one of the variables, then plug it into the derivative while setting it = to the slope of the tangent line and solve for the variable, then simply use that point to find the other one, but it did not work.
Could someone be of assistance and show me how to go about this question, as it is 4 marks and I want to make sure I am prepared for the upcoming test. (For what its worth too I am in the beginning of grade 12 calculus so try and keep any explanation simple :-p)
Thanks in advance guys :smile:.
ok.
Call the point at which the slope of the tg is as you have there [tex](x_0,y_0)[/tex]
then what this means is that you will have a system of two eq. in two unknowns:
[tex]\frac{1}{2\sqrt{3}}=-\frac{x_0}{4y_0}[/tex]
and
[tex]x_0^2+4y_0^2=4[/tex]
I assume you know how to solve for x_0 and y_o right?
[tex][/tex]
Thanks a bunch, and I believe so, do you simply solve one of the equations for a variable (eg. y) and substitute it into the other one and solve for the one variable left, or is this the wrong way?
That is correct! so you will most probbably get two points.
Thanks for all of that help sutupidmath, and you're right, it does come out two points :-p
