How much energy does it take to cool and heat up water
This discussion focuses on calculating the energy required to heat and cool water, specifically addressing two scenarios: heating 95.3 grams of water from -10 degrees Celsius to 35 degrees Celsius and cooling water from 125 degrees Celsius to 75 degrees Celsius. The specific heat capacities used are 2.06 J/g°C for solid water, 4.184 J/g°C for liquid water, and 1.84 J/g°C for water vapor. The calculations yield a total energy requirement of 56.7 kJ for heating and -376.42 kJ for cooling, confirming that cooling results in a negative enthalpy change as energy is lost from the system.
  • Understanding of specific heat capacity
  • Familiarity with enthalpy changes in thermodynamics
  • Basic knowledge of phase changes in water
  • Ability to perform energy calculations using the formula Q = mcΔT
  • Research the concept of enthalpy and its relation to phase changes in water
  • Learn about the calculation of energy changes during phase transitions, including delta H of fusion and vaporization
  • Explore the principles of thermodynamics related to heat transfer and energy conservation
  • Investigate the implications of endothermic and exothermic reactions in various chemical processes
Students studying thermodynamics, chemistry enthusiasts, and anyone involved in energy calculations related to heating and cooling processes.
pooker
1. How much energy does it take to heat 95.3 grams of water from -10 degrees celsius to 35 degrees celsius?
2. How much energy does it take to cool water from 125 degrees celsius to 75 degrees celsius?
specific heat of water in solid is 2.06 j/g c
liquid is 6.01 j/g c
gas is 1.84 j/g c
delta h of fusion is 6.01 kj/mol
delta h of vap is 44 kj/mol
95.7(2.067)(10) = 1093.18 j = 10.93 kj
5.29(6.01) = 31.79 kj
95.3(4.184)(35) = 13955.77 j = 13.95 kj
answer is 56.7 kj
95.3(25)(1.84) = 4384 j = 43.84 kj
5.29(44) = 232.9 kj
25(95.3)(4.184) = 9968.38 j = 99.68 kj
answer is -376.42 kj
Now here is where I am confused. Is it -376.42 kj since it is an endothermic reaction? Or is only part of the reaction negative meaning my answer is completely different? Like when calculating delta h of evaporation would that be positive and the others negative? Or is it right that anytime you cool something off it is all completely negative? My book does not go into detail at all with this. It just gives one answer.
Think in terms of energy exchanged between your water and surroundings. To heat up the water it has to gain energy, hence its enthalpy goes up - and enthalpy change for water is positive. Quite the opposite for cooling.
As Borek said - water has to gain or lose energy to heat and cool, respectively. The enthalpy change is always in relation to the system.
Heating: system gains energy: enthalpy change is positive
Cooling: system loses energy: enthalpy change is negative
Yes, that is correct. Cooling an object is always negative, since it will be losing energy. In much the same way, heating an object is always positive.
If you're looking at successive heating and cooling, you would need to work out each cooling and heating segment separately, be weary of signs, and sum the enthalpies.
11K
  • · Replies 16 ·
