Matter @ speed of light and e=mc^2
The discussion revolves around the implications of Einstein's equation E=mc², particularly in relation to the acceleration of matter to the speed of light and the transformation of mass into energy. Participants explore theoretical aspects, practical examples, and the conservation of energy and momentum in these transformations.
  • Some participants assert that matter cannot be accelerated to the speed of light due to the requirement of infinite energy, while others discuss the implications of E=mc² suggesting that mass can be transformed into energy, which moves at the speed of light.
  • A participant uses an analogy involving money and sandwiches to illustrate the transformation of mass to energy, questioning the logic behind the analogy.
  • Another participant mentions that in the transformation of mass to energy, both energy and momentum must be conserved, providing an example involving electrons and positrons converting to photons.
  • One participant discusses the behavior of light in different media, noting that while photons slow down in materials like glass, protons can exceed the speed of light in those same materials.
  • There is a discussion about the concept of mass conservation, with some participants clarifying that the total mass does not change in certain transformations and referencing related threads for further context.
  • Participants express uncertainty about the specific type of mass being referred to, with a focus on rest mass in the context of photon interactions.
Participants generally express multiple competing views regarding the acceleration of matter, the transformation of mass to energy, and the conservation of mass. The discussion remains unresolved with no consensus on these complex topics.
There are limitations in the discussion regarding the assumptions made about energy, mass, and the conditions under which transformations occur. Some statements depend on specific definitions and interpretations of mass and energy.
Pjpic
I seem to have read that matter can't be accellerated to the speed of a photon because it would take an infinite amount of energy. But it seems that mc^2 = E means that matter can be transformed to E (and doesn't E move at the speed of light?)
Science news on Phys.org
But when that matter has been transformed into "energy", it is no longer identical to that matter and it can do whatever an "energy" can do.
When you tranform $10 into a sandwhich, you can now eat that sandwich. Does this mean that your $10 bill can also be eaten like that sandwich? How tasty is that? Probably if you drown it in a lot of ketchup.
Zz.
But, I thought the rule was that you'd have to have an infiinte amount of money to catch the sandwich. Maybe, you could hand over the $10 at the exact same time as you ate.
In the transformation of mass to energy, you have to conserve both energy and momentum (and quantum numbers). Consider an electron in a piece of aluminum. Stop a positron in it. It will find an electron and both masses will be converted to pure energy; two 511 keV photons. So here both energy and momentum are conserved.
You are not interesting in figuring out on what is wrong with your "logic", are you?
Zz.
Pjpic said:
I seem to have read that matter can't be accellerated (sic) to the speed of a photon because it would take an infinite amount of energy. )
When a light beam passes through a clear glass disk with index of refraction n, the velocity of the photons in the glass are reduced to a value v = c/n, or about 2/3 the velocity of light. When a proton from the Fermilab Tevatron, with an energy equal to about 1000 proton rest masses and speed nearly the speed of light, passes through the glass, its velocity would be nearly 1.5 times the velocity of the photons. So matter can travel faster than the speed of light, but not in a vacuum.
No, the total mass doesn't change. See related threads.
Pretty sure he means rest mass...
...me too.
I'm not joking, see related threads. For example, post #45 of this thread:
https://www.physicsforums.com/showthread.php?t=289508&page=3
The two photons in the example used by Bob S don't move in the same direction(*), so their mass (the mass of the two photon's system) is different than zero.
(*)In the thread cited in the link jtbell talks about two photons moving in opposite directions, but the result is the same, because in another frame of reference they moves at another angle; what counts is the fact that they don't move in the same exact direction.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 16 ·
