Basis of the vector space of solutions to a differential equation.
The basis of the vector space of solutions to the differential equation (y'' + 5y' - 50y = 0) is defined as {e^(5x), e^(-10x)}. The general solution can be expressed as y(x) = Ae^(5x) + Be^(-10x), where A and B are constants. To form a basis, specific values for A and B must be chosen such that A + B equals one, leading to particular solutions like y1 = s*e^(5x) + (1-s)e^(-10x) and y2 = t*e^(5x) + (1-t)e^(-10x). The book's answer is derived from selecting A=1 and B=0.
  • Understanding of second-order differential equations
  • Knowledge of linear combinations in vector spaces
  • Familiarity with exponential functions and their properties
  • Basic skills in solving differential equations
  • Study the method of characteristic equations for solving linear differential equations
  • Learn about the Wronskian and its role in determining linear independence of solutions
  • Explore the concept of vector spaces in the context of functional analysis
  • Investigate applications of differential equations in physics and engineering
Students and professionals in mathematics, particularly those studying differential equations, linear algebra, and vector spaces. This discussion is beneficial for anyone looking to deepen their understanding of solution bases in differential equations.
PhysicsKid42
Apologies, have solved this question.
Answer if useful for anyone:
Basis= {e^(5x),e^(-10x)}.
Consider the differential equation
(2nd derivative of y wrt x) + 5(1st derivative of y wrt x) - 50y =0
Find a basis of the vector space of solutions of the above differential equation. You should separate each vector with a comma, and each should take the value of 1 at x=0
Solution: y(x)=Ae^(5x) + Be^(-10x)
The solutions are a linear combination of these two terms.
I'm unsure of how to convert this into 'a basis of the vector space of solutions'.
So take values of A and B, to give particular solutions. List them.
The value must not be the same and A+B must equal one.
say s!=t
y1=s*exp(5x)+(1-s)*exp(-10x)
y2=t*exp(5x)+(1-t)*exp(-10x)
Basis={y1,y2}={s*exp(5x)+(1-s)*exp(-10x),t*exp(5x)+(1-t)*exp(-10x)}
you can also just chose particular s and t
s=10,t=101
Basis={y1,y2}={10*exp(5x)-9*exp(-10x),101*exp(5x)-100*exp(-10x)}
The book answer results from the choice s=1,t=0
  • · Replies 27 ·
