Flux through a loop of wire in a magnetic field.
The problem involves calculating the magnetic flux through a wire loop in a uniform magnetic field, specifically a 4.5 T field passing perpendicularly through a loop with an area of 0.10 m².
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to apply the flux equation but questions the use of cosine in relation to the angle of the magnetic field and the loop's orientation. Some participants clarify the definition of the area vector and its relationship to the magnetic field direction.
The discussion has evolved with participants exploring the implications of the angle used in the flux calculation. There is a realization regarding the correct angle to use, indicating a productive direction in understanding the problem.
Participants are navigating assumptions about the orientation of the loop and the magnetic field, particularly the definitions of angles in the context of magnetic flux.
einsteinoid
A uniform 4.5 T magnetic field passes perpendicularly through the plane of a wire loop .10 m^2 in area. What flux passes through the loop?
Flux = (B)(A)[cos(theta)]
Ok, according to my understanding. The equation should be set up as such:
flux = (4.5)(.10)[Cos(90)]
The cosine of 90 degrees, obviously, is zero therefore there should be no flux through the wire loop, correct? The answer sheet to this review is saying that the answer to this problem is
(b) .45 Tm^2
This would be true if the equation was the "sine of theta" rather than the cosine of theta, right? Is my equation wrong or is the review sheet wrong?!
Thanks,
-Will
The normal to the plane of the loop is parallel to the B-field.
With respect to area, the area vector is perpendicular (normal) to the area surface by convention.
And perpendicular = 90 degrees, so my equation should reduce to zero because the cosine of 90 degrees is zero?
Or am I missing the point of your post? lol
Oh i get it! Haha, duh.
The normal is perpendicular to the surface making the angle 0 degrees. Cosine of 0 is 1. Yeah, I'm running on very little sleep, lol.
thanks, Astronuc.
  • · Replies 21 ·
  • · Replies 37 ·
