What is the correct voltage current eq. for a variable capacitance capacitor?
The correct voltage-current relationship for a variable capacitance capacitor is defined by the equation I = dQ(t)/dt = V(t) * dC(t)/dt + C(t) * dV(t)/dt. This equation accounts for the time-varying capacitance, C(t), which is influenced by the distance between the capacitor plates, d(t). The standard equation i(t) = C * dv/dt applies only when capacitance is constant. Understanding this relationship is crucial for analyzing circuits involving variable capacitors.
  • Understanding of capacitor fundamentals, including capacitance and charge.
  • Familiarity with calculus, specifically differentiation.
  • Knowledge of electrical circuit analysis techniques.
  • Basic understanding of variable capacitance concepts.
  • Study the derivation of the equation Q(t) = C(t)V(t) for variable capacitors.
  • Learn about the implications of time-varying capacitance in circuit design.
  • Explore practical applications of variable capacitors in electronic circuits.
  • Investigate the effects of mechanical adjustments on capacitance and circuit behavior.
Electrical engineers, circuit designers, and students studying advanced capacitor applications will benefit from this discussion, particularly those working with variable capacitance in experimental setups.
simplex
What is the correct voltage - current equation for a variable capacitance capacitor?
If the capacitor has a fix value, C, then the following expression holds:
i(t)=C*dv/dt,
where i is the current that charges the capacitor and v the voltage across it.
If C=C(t) then i(t)=C(t)*dv/dt ?!.
Something tells me that this formula is wrong. I am not sure 100% but it looks wrong.
What I need is the correct relation between i(t) and v(t) when C=C(t).
Can I get some help from you?
Description of the problem in detail:
I have a capacitor whose capacitance, C is a function of time, t. More precisely, the distance between its plates is varied in time, by a mechanical device, according to a known law d=d(t) where d(t) is a function of t only and does not depend of the voltage, current, etc.
As d=d(t) and C=eps*S/d, also C=C(t). So, I can say that I have a capacitor whose capacitance changes in time according to a known, given function, independent of the voltage, current and other electrical parameters and dependent only of the time, t.
This variable capacitor is part of a circuit and as long as I do not know the current - voltage equation of it, I can not go further to analyze the behavior of the circuit which I need for an experiment.
i(t)=C*dv/dt,
The important equation here is:
Q(t) = C(t)V(t)
So,
[tex]I = \frac{dQ(t)}{dt} = V(t)\frac{dC(t)}{dt}+C(t)\frac{dV(t)}{dt}[/tex]
  • · Replies 22 ·
