F(x) = (e^x)/x. at what value of x does f(x) attain its minimum
  • Thread starter Thread starter meredith
    Minimum Value
The problem involves the function f(x) = (e^x)/x and seeks to determine the value of x at which f(x) attains its minimum. The discussion revolves around calculus concepts, particularly derivatives and critical points.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of the derivative and the appropriate application of the product or quotient rule. There are questions about the correctness of the derivative and the method for finding critical points. Some participants explore the nature of local minima versus global minima.
The discussion is ongoing, with various interpretations of the function's behavior being explored. Some participants have offered guidance on finding critical points and evaluating the second derivative, while others challenge the existence of a minimum and suggest alternative values of x that yield lower function values.
There is a debate regarding the definition of minimum in the context of the function, with references to local versus global extrema and the behavior of the function as x approaches certain limits.
meredith
f(x) = (e^x)/x. at what value of x does f(x) attain its minimum
f'(x) = (x)(e^x) / (e^x)
then do i set both of those to 0 and solve?
how o i do that?
im losttt
Well, that is something you could do, but it would only work if your derivative is correct and I don't think that it is.
That's not the derivative. To get the derivative you need to use the product (or quotient) rule:
(fg)' = fg' + gf'
This equals e^x/x - e^x/x^2 = (e^x/x)(1-1/x)
You need to set this equal to 0 and solve for x to find the critical points of f. To find all local minima, find all points for which the 2nd derivative is positive. To find the minimum, you need to compare all the values of the local minima and take the smallest one. You also need to look at boundary points, which in our case would be +infinity and -infinity.
This problem's solution is easy to see since there is only one critical point.
at x=1 we would have the minimum
because x=1 is the only critical point after we equate first derivative =0
and second derivative is>0 at x=1 so minima occurs
"at x=1 we would have the minimum
and second derivative is>0 at x=1 so minima occurs "
I believe this answer is incorrect, if one answers the specific question the OP is asking. I can throw out a value of x where the f(x) < f(1).
Your answer may be right, if one means to talk about local extrema.
csprof is right. It's a stupid question, because there is no minimum (by definition - either the authors didn't understand this or they did this as a trick question). The infimum is 0, which occurs at x=-infinity. There is no minimum. The only local minimum is at x=1.
What about x = -0.000000000001? exp(x) ~ 1 and 1/x = -1,000,000,000,000. Looks like f(-0.000000000001) < f(1) < lim f(x) as x -> -inf.
phreak said local minimum. x= -0.00000000001 is not vry "local" to 1!
I wasn't taking issue with his statement regarding the local minimum... just pointing out that, as should be clear to everyone, the function goes to -infinity as x approaches zero from below.
  • · Replies 18 ·
