How to use the gradient to find Electric field
The discussion focuses on calculating the electric field at the center of a semi-circular rod with a uniform charge distribution. The electric potential at the center is expressed as V = kQ/r or V = k(pi)(lambda), where lambda represents the charge density. The correct electric field expression derived is E = 2k(lambda)/r. The confusion arises from incorrectly applying the gradient of the electric potential, leading to an erroneous result of kQ/r^2. Properly accounting for the gradient along the radius and summing contributions from the semi-circular rod is essential for accurate calculations.
  • Understanding of electric potential and electric field concepts
  • Familiarity with calculus, specifically gradient operations
  • Knowledge of charge distribution and linear charge density
  • Basic principles of electrostatics and field calculations
  • Study the derivation of electric fields from electric potentials in electrostatics
  • Learn about the application of gradient in vector calculus
  • Explore the concept of charge density and its implications in electric field calculations
  • Investigate the superposition principle in electric fields for complex charge distributions
Physics students, electrical engineers, and anyone studying electrostatics or working on problems involving electric fields and potentials.
howell
1. A rod carrying a uniform charge distribution is bent into a semi circle with the center on the orgin and a radius R. calculate the Electric field at the center of the semi circle using the electric potential expression found in part a
2. E = -(gradient)V
3. The electric potential at the center is V = kQ/r or k (pi) (lambda) where lambda is the charge density. The correct expression for the electric field at the center of the circle is 2k(lambda)/r. However, I'm finding that simply taking the gradient of the electric potential function gives kQ/r^2 or k(lambda)(pi)/r, which is not correct. I'm afraid I'm making a fundamental mistake with the definition of the gradient and how to account for the changing electric field direction at the center of the semi circle.
Here you have taken the gradient along the radius.
First you have to finds out delta Ex( due to a small element dl) = -dV/dx and dEy = - dv/dy where dx = dr*cos (theta) and dy = dr*sin(theta). Take summation over the whole semicircular rod to find the field.
  • · Replies 16 ·
  • · Replies 22 ·
