Thread Closed
Steps for calculating dc generator output potential
Share Thread
Mar9-09, 02:04 AM   #1
I need help understanding a few different items regarding electromechanics, and I'm not really sure where to start. Though the figures I have provided immediately seem impractical (coil melt down, coil explosion due to excessive rpm, inside dimensions exceeding their respective outside dimensions when certain figures are added together, ect), they are the numbers I must work with.
Wire properties:
Enamel copper motor wire.
AWG 24 (0.0201 in dia).
Wire length: 40,000 feet
Turns of wire in coil: 46462.84
Coil RPM: 18,364,800
Coil distance from magnets: .05 inches
Magnet properties:
Material: Neodymium
Pull Force: 705.23 lbs
Surface Field: 5630 Gauss
Brmax: 14,800 Gauss
BHmax: 52 MGOe
I am unsure if magnetic fields "stack" (double, triple, ect) when they are close or put together, but if they do then assume that two of those magnets are .6 inches in distance from and parallel to, each other. Also assume that the coil is .5 inches in width and would be between those magnets.
Basically, how would I even start calculating the types of output this would generate? Volts, watts, amps -- you name it.
Thanks in advanced. :)
Edit:
Do you think the appropriate first steps would be something along the lines of this.
Calculate weight of copper mole: 63.549g
Calculate copper weight of wire: 22188.650118g
Divide weight of mole by total weight of wire to get number of moles: 349.174615
Multiply number of moles by Avogadro's Number to get number of total atoms (6.02)(10^23):
Multiply number of total atoms by number of electrons in a single atom to get total number of electrons in circut (29):
Calculate percent error:
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Mar11-09, 08:24 PM   #2
Bump?
Mar11-09, 09:11 PM   #3
What are dimensions of this generator? Is the copper wound on a stator or on an armature? Does the generator have a commutator or slip rings on the armature? Does the generator have diode rectifiers (like an automobile)? Does the generator have a neodymium magnet armature? Do you commutate the exciting current with a Hall effect probe? Your RPM is much too high.
Thread Closed
Similar discussions for: Steps for calculating dc generator output potential
Thread Forum Replies
Peak voltage output of a generator Introductory Physics Homework 3
Barrier potential with N steps...(and she's climbing the potential stariway to la...) Advanced Physics Homework 0
electrical generator- governing laws for RPM to voltage output Electrical Engineering 6
what is the formula to solve for RPM to volatage output in a generator Engineering, Comp Sci, & Technology Homework 2
