Simple math question. |
Mar9-09, 02:38 PM
#1
ultimablah is
Offline:
The sum of four numbers equals the product of four numbers equals 711.
What are the four numbers?
I see 2 equations with 4 unknowns, and no way to do this but brute force it; is there a special circumstance here?
Mar9-09, 02:53 PM
#2
Werg22 is
Offline:
Re: Simple math question.
The sum and product of the same 4 numbers are equal to 711? Is that what you mean?
The prime decomposition of 711 is 3^2*79. There aren't too many ways to get 4 numbers; you either have 1, 1, 9, 79, or 1, 1, 3, 237 or 1, 3 , 3, 79. None of those sum up to 711. Can you restate the problem more clearly?
Mar9-09, 06:53 PM
#3
davee123 is
Offline:
Admittedly, he did say "numbers" and not "integers", so the prime factorization of 711 isn't necessarily relevant, although I agree it's certainly implied. Hmm...
DaveE
Mar9-09, 10:08 PM
#4
ƒ(x) is
Offline:
Hm...Just thinking out loud here. This approach requires making certain assumptions that could prove to be wrong. Please forgive my formatting errors.
711 = a+b+c+d
711 = abcd
The first two assumptions are that a = 711, so:
0 = b+c+d
1 = bcd
The next one is that bc = 1, which means that
d = -1
and
-1 = bc
and that
-1/b = c
which means that
711 = 711-1+(-1/b)+b
0 = -1-(1/b)+b
0 = b^2-b-1
b = [1+-(1-4*-1*1)^1/2]/2
b = [1+-(5)^1/2]/2
b = 1.618 or -.618
Therefore, since -1/b = c
When b = 1.618, c = -.618 and when b = -.618 c = 1.618
And that since addition and multiplication are communicative, one of these solution is redundant.
So, in conclusion (finally  )
Since -1 = bc
711 ?= 711*-1*-1
711 = 711
and
711 ?= 711-1-.618+1.618
711= 711
a = 711
b = -.618
c = 1.618
d = -1
Q.E.D.
Mar10-09, 02:31 AM
#5
jimmysnyder is
Offline:
As the op said, these are two equations in 4 unknowns. There are infinitely many solutions. F(x) has added 3 more equations which seems extravagant under the circumstances.
Mar10-09, 05:52 AM
#6
ƒ(x) is
Offline:
Haha. Nevertheless, those three extravagant equations allowed me to find one possible solution.
Oh, and by the way, prove that there are a infinite number of solutions.
Mar10-09, 12:25 PM
#7
davee123 is
Offline:
That's pretty easy, no?
w+x+y+z = 711
wxyz = 711
w = 711/xyz
Assume z=1:
w=711/xy
711/xy+x+y+1 = 711
711 + x^2y + xy^2 = 710xy
xy^2+(x^2-710x)y+711 = 0
You can use the quadratic formula (though it's messy) to solve for y, with:
A = x
B = x^2-710x
C = 711
So as long as 2A =/= 0, and B^2 > 4AC, you're good. Specifically:
x =/=0
x^4+2x^2-1420x+504100x^2 > 2840x
x^3+2x+504100x > 4260
So, without bothering to solve it, it's obvious that for x>1, the quadratic will be solvable, because it'll satisfy the above requirements. And obviously there are an infinite number of values for x>1.
DaveE
Mar10-09, 12:38 PM
#8
jimmysnyder is
Offline:
My bad. f(x) only added two equations, the expected number. As not both of the original equations are linear it is not enough to merely count equations and unknowns as I did. However, davee123 has saved the day for me on this point.
Mar11-09, 07:11 PM
#9
ƒ(x) is
Offline:
Haha fine. I'm too tired to look through your post right now, so I'll just agree for the moment.
Just as a side note, my math teacher has a problem that is exactly similar to this one that that he calls the "7-11 Problem" (as in the gas station). When asked, he said that there was only 1 possible solution to this, and I am tempted to agree because the problem combines addition and multiplication. But, he is not infallible.
