Volume/volume and weight/weight persentages of the constituents in a composite
  • Thread starter Thread starter mitnord
    Composite
The discussion focuses on calculating the volume/volume and weight/weight percentages of aluminium and lead in a composite material with a density of 8.3 g/m³. It emphasizes that knowing the total volume is unnecessary since density is independent of volume. By applying the equations for density and volume, specifically using the formula (DensityAl * VolumeAl) + (DensityPb * VolumePb) = (AverageDensity * TotalVolume), users can derive the required ratios. The assumption of a total volume of one cubic meter simplifies the calculations, allowing for the determination of the constituent percentages.
  • Understanding of basic density and volume concepts
  • Familiarity with algebraic equations
  • Knowledge of the densities of aluminium and lead
  • Ability to manipulate equations with two variables
  • Research the densities of aluminium (2.7 g/cm³) and lead (11.34 g/cm³)
  • Learn how to set up and solve systems of equations
  • Explore Archimedes' principle and its applications in material analysis
  • Study composite material properties and their implications in engineering
Materials scientists, engineers, and students studying composite materials or density calculations will benefit from this discussion.
mitnord
Hi,
I have an aluminium/lead composite material with density of 8,3 g/m^3. How do I find volume/volume and weight/weight persentages of aluminium and lead in the material, if the masses of the composites are not given?
The volume of the material is also not known.
Thanks.
You don't need to know the volume since the density is independent of volume.
8,3 grams per cubic metre sounds remarkably small for something involving metals!
You know Archimedes sorted this out for a king who wasn't sure that his crown was pure gold or alloyed with silver.
VolumeAl + VolumePb = TotalVolume
Assume TotalVolume to be one cubic metre. You know the three densities (or you can look them up) so you've got two equations and two unknowns.
From that you can work out the ratios you are looking for.
  • · Replies 17 ·
