Linear Independence of Given Vectors: Explanation and Steps
  • Thread starter Thread starter chealsealee
The discussion revolves around determining the linear independence of two sets of vectors in a vector space. Participants are exploring definitions and methods related to linear dependence and independence.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest using determinants of matrices formed by the vectors to assess linear independence. Others propose a definition-based approach, discussing the conditions under which vectors are considered linearly independent or dependent.
The conversation includes various methods for determining linear independence, with some participants questioning the implications of definitions and the appropriateness of certain approaches. There is no explicit consensus on a single method, but multiple perspectives are being explored.
Participants express concern about the nature of the discussion, with some suggesting that the original poster may be seeking direct answers rather than engaging with the learning process.
chealsealee
help me in this question!
given the following vectors,
1. (8 0 4),(0 2 0),(4 0 2),(0 4 0)
2.(0 3 4),(-3 0 5),(-4 5 0)
linearly independent or linearly independent? why??
show the steps, please!
Too easy. This is HW, isn't it?
Make the three vectors the three columns of a 3x3 matrix. Find the determinant. If the determinant is zero, linearly dependent. Else, linearly independent.
csprof2000 said:
Too easy.
I'm afraid you should have first given a definition of easy...(sorry for this)
To the OP: if you are interested in another method without utilizing determinants then here we go. What does it mean for a set of vectors to be lin. dependent or lin. independent?
Let:
[tex]v_1,v_2,...,v_n[/tex] be a set of vectors in R^n. Then this set of vectors is said to be lineraly independent if there exists a trivial linear combination equal to zero. In other words, if the following dependence relation:
[tex]c_1v_1+...+c_nv_n=0[/tex] ----(@)
is possible only and only for [tex]c_i=0,\forall i \in N[/tex]
Now,the question, naturally, might arise how to determine c_i's? right?
Well, let's look at it this way, if we would define a matrix A, such that v_i's are its columns, i.e
[tex]A=[v_1,v_2,...,v_n][/tex]
Then (@) actually is the following homogeneous matrix equation Ax=0 ---(@@)
Where [tex]x=[c_1,...,c_n]^T[/tex]
Now, all you need to do is solve (@@), and see whether you have one unique solution(which will be your trivial solution, and thus the vectors will be lin. independent), or it will have infinitely many solutions,(in which case the vectors will be lin. dependent).
Let:
There always "exists a trivial linear combination equal to zero"!
You should say "if there does NOTexist a non-trivial linear combination equal to zero".
You are right Halls as always. Yeah, what i meant to say is that if the only linear combination equal to zero is the trivial one.
You guys do realize you are doing the homework for the OP...?
  • · Replies 18 ·
  • · Replies 17 ·
