How Does Time Dilation Work in Relativity?
Time dilation in the context of relativity is quantitatively expressed by the formula dt' = ydt, where dt represents the time interval between two events in frame S, and dt' is the time interval in frame S', which is moving at a constant velocity relative to S. The observer in S' measures a longer time interval than the observer in S, as the Lorentz factor (y) is greater than 1. This phenomenon occurs because the observer for whom the two events occur at the same location measures the shortest time interval. Understanding this concept is essential for grasping the implications of Einstein's theory of relativity.
  • Understanding of Einstein's theory of relativity
  • Familiarity with the Lorentz factor (y)
  • Basic knowledge of inertial reference frames
  • Mathematical proficiency in algebra
  • Study the implications of the Lorentz transformation in detail
  • Explore the concept of simultaneity in different reference frames
  • Learn about the twin paradox and its relation to time dilation
  • Investigate experimental evidence supporting time dilation, such as muon decay rates
Physics students, educators, and anyone interested in understanding the principles of relativity and time dilation effects in high-velocity scenarios.
Master J
Time Dilation...what it means
I am trying to get my head around some of the basics of relativity.
dt' = ydt
Where dt is the time between 2 events in frame S, and dt' is the time between the same events in frame S', that is moving witha constant velocity relative to S.
What exactly does this say? Does it mean that the observer in S' will measure a greater time interval than in S, or that the observer in S will see the time interval in S' as longer than his?
Like if it means that the observer in S' will measure a greater time interval, well howcome the observer in S doesn't, since one could equally say that he is moving relative to S'?
I hope you guys can sort this out, its just tricky to get the hang of.
The formula is valid only if the two events happen at the same place in S, not in S'. It says that in this case, S' measures a longer time between the events than S, since y>1. Generally, the observer for which the two events happen at the same place measures the shortest time.
  • · Replies 54 ·
  • · Replies 88 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 60 ·
