Thread Closed
Euler Buckling
Share Thread Thread Tools
Mar10-09, 06:22 PM   #1
Euler Buckling
I want to find the euler buckling for a open I beam( middle section like a box) that is subjected to three point bending with a point load on top.
I am not so interest in a solution but explanation on how this could be worked out using the euler equation for buckling.
2. Relevant equations
Pcr=(PI^2)EI/L im pretty sure this is for a column with pinned ends but don't know how to work out one for an i beam in 3 point bending
3. The attempt at a solution
Don't want a solution can put numbers in myself
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar12-09, 09:10 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by THE 1 View Post
If you are talking about an I beam subject to both bending stresses and axial compressive stresses, then the beam-column design would be governed by the applicable Steel Code. Now mind you I haven't kept up with the latest Code revisions, but generally speaking, especially when the actual axial stress is small compared to the allowable axial stress, stresses would have to satisfy the following formula:
[tex]f_a/F_a + f_b/F_b <= 1.0[/tex] , where
[tex]f_a[/tex] = actual design axial compressive stress
[tex]F_a[/tex] = Allowable axial compressive stress as if there were no bending (this is generally the Euler buckling stress pi^2EI/KL^2(A) for K=1, with appropriate safety factors)
[tex]f_b[/tex] = actual design compressive bending stress
[tex]F_b[/tex] = Allowable compressive bending stress as if there were no axial load (this allowable stress must take into account lateral torsional buckling of the flange due to the compressive bending stresses, with appropriate safety factors).
Thread Closed
Thread Tools
Similar Threads for: Euler Buckling
Thread Forum Replies
experimental buckling load Mechanical Engineering 12
Prove Euler Identity without using Euler Formula General Math 36
Statics Problem; buckling Engineering, Comp Sci, & Technology Homework 0
Results same w/ Euler, Improved Euler, & Runge-Kutta Differential Equations 14
Buckling calculation Classical Physics 7
