Is Movement Through Space-Time Really Possible?
  • Context: Graduate
  • Thread starter Thread starter menergyam
    Space-time
The discussion revolves around the nature of movement through space-time, questioning why objects must move through both space and time rather than independently. Participants explore theoretical implications, mathematical models, and conceptual understanding related to space-time in the context of physics, particularly general relativity and special relativity.
  • Some participants express confusion about why objects cannot move only through space or only through time, questioning the fundamental nature of space-time.
  • It is suggested that objects at rest move only through time, while light is described as moving through space without experiencing time.
  • Some argue that space and time are independent dimensions, while others assert that they are fundamentally connected, particularly in the context of reference frames.
  • One participant raises the idea that if an atom is cooled to near absolute zero, it could be considered to be moving only through time, leading to questions about the implications of such a state.
  • There is a discussion about the concept of moving infinitely fast if an object were to traverse a distance in zero time, with references to the speed of light as a limiting factor.
  • Some participants challenge the notion of absolute rest and frame of reference, emphasizing that motion is relative and cannot be defined without context.
  • The conversation touches on the philosophical aspects of movement and the interpretation of time as a dimension that can be mapped, leading to varied interpretations of what it means to "move."
Participants do not reach a consensus on the nature of movement through space-time. There are multiple competing views regarding the independence or connection of space and time, as well as differing interpretations of motion and reference frames.
Limitations include the reliance on specific definitions of movement, the absence of absolute frames of reference, and unresolved questions about the implications of theoretical scenarios such as absolute rest or movement through time without spatial displacement.
menergyam
One thing that I really never understood is why space-time is connected. I have not taken general relativity yet, so I don't know the mathematics yet, but I want to know the answer.
Why does an object have to move through space-time? Why can't an object move only through space or only through time? Are the mathematical equations that describe space-time just imply that they are connected? Is it proven with experimental evidence? Or is it proven with mathematical equations that space and time are connected? Or is space and time connected because of a real fundamental reason?
Welcome to PF!
Hi menergyam! Welcome to PF! :smile:
An object can move only through time …
most of the objects you're looking at right now are doing exactly that :wink:
and if an object moved only through space (and not through time), then it would be moving infinitely fast
Objects at rest move only through time. And you can think of light as moving only trough space, as it doesn't experience any time passing:
http://www.adamtoons.de/physics/relativity.swf
They are not "connected", as they are fully independent dimensions. Putting them into one diagram doesn't mean anything physically.
There is nothing to prove here. Spacetime is just a mathematical model used to describe experimental observation.
Everyone's so awesome!
Wait, How can you tell if something is at absolute rest? You can only tell if something is at rest relative to something else. There is no absolute frame of reference, that's what I learned in special relativity. Also, our solar system is revolving around our galaxy, and our galaxy is moving relative to other galaxies. Therefore, we can't tell if something is moving only through time itself. Also, light does not move infinitely fast, it moves at the speed of light. Therefore, I am still confused, and my question is still not answered. Why can't an object move only through time or only through space?
There's no objective or absolute sense in which something can be moving "only through time", you can only talk about the amount of "movement through time" vs. "movement through space" relative to a particular (arbitrary) choice of reference frame.
I thought I read that all objects are moving through spacetime at c. So an object could either move through space at c and time at 0, time at c and space at 0, or some combination of the two. Why do you say it has to move infinitely fast?
I was replying to tiny-tim when I was saying an object can not move infinitely fast.
When you say that I can only talk about the amount of movement through time vs. movement through space, do you mean that by saying otherwise is pointless? Because there is no absolute sense? Since no absolute sense exists then my question does not exist as well, am I interpreting your answer correctly?
You left out the key part of that sentence...you can only talk about those things relative to a particular choice of reference frame.
What do you mean by "saying otherwise"? It is indeed meaningless to talk about the amount of movement through time or space without specifying the context of what reference frame you're using...there is no absolute, frame-independent truth about how much you're moving through time or space.
Okay, to clear up what I mean. I am taking into consideration about the frame of reference this time.
For example, I use a laboratory room on Earth as my reference frame. If an atom is cooled to a few millionths of a degree above 0 K in the laboratory, then can't we say that this atom is not moving? It would possesses very little kinetic energy. Wouldn't this atom be moving only through time and very little distance through space? This atom would exist in the same location for as long as it is in its cooled state. If the atom actually reached 0K, (I think this is not possible) wouldn't this mean that it travels through absolutely 0 distance relative to the laboratory?
Now, what I really want to know is the opposite in the scenario I said above. Can this atom move a certain distance say 10^12 meters in absolutely 0 time relative to the laboratory? This would mean that it moved, infinitely fast because you would be dividing by 0 to calculate speed.
For the motion of the atom to be completely confined to space and none of it in time, it will have to move at the speed of light like a photon.
Hi menergyam! :smile:
menergyam said:
Wait, How can you tell if something is at absolute rest? You can only tell if something is at rest relative to something else. There is no absolute frame of reference, that's what I learned in special relativity. … Therefore, I am still confused, and my question is still not answered. Why can't an object move only through time or only through space?
Ah … this shows that space and time are connected …
when I said that a stationary object moves only through time (and not through space), that only applies in one frame. In any other frame, it moves through both space and time.
The phrase "motion only through time in any frame" makes no sense, since space and time are connected. :smile:
I didn't say it can … I said "if …" :wink:
A contrare (in my best continental accent). Things don't move through time. Things only move in space.
contrariare
Au contraire (in my best continental spelling) …
it depends what you mean by "move" :wink:
What are you doing up so late? It's nearly 4am here. What's the world coming to?
To "move" means to change from one place in space to another.
Now enter the world of maps where we pretend we are outside of space and time, looking in. Time is mapped onto some sheet of paper or our imagination to a spatial extent. So for this we have a "map language" so we can talk about the map without making grammatical errors. This is fine as long as everyone knows we are talking about the map. We look at all of time, or some amount of it as if it's a spatial extent. This way it makes map-sense to say things like "the future is", instead of "the future will be". Objects are now lines in spacetime. But nothing moves on the map. It's just a line of mappish present tense.
When people talk about moving through spacetime at c, and how this is divided up into moving through space and moving through time, they are making use of a particular definition of "movement through spacetime" and "movement through time" which may not be totally intuitive (and in fact you won't typically see these terms defined in a relativity textbook, it's a mathematical trick which I've only seen a few authors like Brian Greene make use of--see my post #3 on this thread for a quote from one of Greene's books where he explains the math). Basically, the "rate of movement through time" in a particular frame is defined as c times the ratio of the object's proper time (clock time) to coordinate time in that frame...so, if an object's clock is slowed down by a factor of two, its "speed through time" is then defined as 0.5c. Since time dilation approaches infinity as you approach the speed of light, under this definition your "speed through time" would be zero at the speed of light, it would not require you to move infinitely fast.
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 32 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 32 ·
