Solving Particle Collision: Find Mass Ratio from Total Angle
The discussion focuses on calculating the mass ratio of two particles involved in an elastic collision based on their post-collision angles. The user solved for a specific case where m1 equals 20 and angles theta1 at 55.6 degrees and theta2 at 50 degrees, resulting in m2 equal to 40. The conversation emphasizes the need for a formula to determine the mass ratio from the total angle after the collision, utilizing conservation of momentum and kinetic energy principles. A correction was made to the y-direction momentum equation, highlighting that the correct formulation should be m1v1sin(theta1) + m2v2sin(theta2) = 0.
  • Understanding of elastic collisions in physics
  • Familiarity with conservation of momentum and kinetic energy principles
  • Basic knowledge of trigonometry, specifically sine and cosine functions
  • Ability to manipulate algebraic equations
  • Research the derivation of mass ratios in elastic collisions
  • Learn about the application of conservation laws in two-dimensional collisions
  • Explore the use of trigonometric identities in physics problems
  • Investigate simulation tools for visualizing particle collisions and angle relationships
Physics students, educators, and researchers interested in particle dynamics, particularly those focusing on collision mechanics and mass ratio calculations.
twentysix26
So there is a particle with m1 that hits a particle m2 at rest, they bounce off at angles theta1 and theta2 from the horizontal. The original problem proposes that you can find the mass of the second particle from knowing the first particle, and the angles that they both make from the horizontal after the elastic collision. So i solved the equation when m1 = 20 and theta1 = 55.6 degrees and theta2 = 50 degrees, and i found out that m2 = 40.
But what I am trying to find is an easier way to solve, so a formula to discover the ratio of the two masses from the total angle after the elastic collision
So conservation of momentum in x-direction:
m1v (before)= m1v1cos(theta1) + m2v2cos(theta2) (after)
y-direction:
m1v1sin(theta1) - m2v2sin(theta2) = 0
conservation of KE:
1/2(m1)(v^2) = 1/2(m1)(v1^2) + 1/2(m2)(v2)^2
help please
Here's the equation that my friend and I found...
We can find the ratio based off of the observed angles. We want to know how to find the angles (or spread) that result for any given ratio of masses.
Py is wrong
y-direction:
Negative angles correlate to negative sin..
it should be: m1v1sin(theta1) + m2v2sin(theta2) = 0
With that modification the equation becomes what I have attached.
What puzzles me is how a span of 105.6 does not always correlate to 2m1=m2...
A span of 90 always correlates to m1=m2...
  • · Replies 35 ·
  • · Replies 30 ·
