Is the Continuity Equation a Restatement of Gauss' Divergence Theorem?
  • Context: Graduate
  • Thread starter Thread starter ballzac
    Divergence
The discussion centers around the relationship between the continuity equation and Gauss' divergence theorem, exploring whether the continuity equation can be viewed as a formulation of the theorem. Participants delve into the derivation of the continuity equation, its implications in classical and quantum contexts, and the conditions under which these mathematical principles apply.
  • One participant describes the continuity equation as related to local conservation and questions if it can be considered a formulation of Gauss' divergence theorem.
  • Another participant outlines a detailed derivation of the continuity equation, emphasizing the transition from a material system perspective to a geometric perspective, and the application of Gauss' theorem in the derivation process.
  • A later reply suggests that if a measurement were to violate the continuity equation, it could imply either a false measurement or a misapplication of Gauss' theorem, but does not assert that the theorem itself would fail.
  • Some participants acknowledge the relevance of the continuity equation in quantum mechanics, specifically in relation to the continuity of probability current.
Participants express differing views on the relationship between the continuity equation and Gauss' divergence theorem. While one participant argues that the continuity equation is not merely a restatement of the theorem, others explore hypothetical scenarios regarding measurements and their implications for both equations, indicating that the discussion remains unresolved.
The discussion includes assumptions about the applicability of Gauss' theorem and the conditions under which the continuity equation holds, particularly in classical versus quantum contexts. Some steps in the derivation are not fully resolved, and the implications of potential measurement discrepancies are left open-ended.
ballzac
I have followed a derivation of the continuity equation, and it uses the divergence theorem at some point, but looking at the actual meaning of the equation, it almost seems like it is saying the same thing as the theorem. That is, local conservation. So my question is...
Can the continuity equation be considered a formulation of Gauss' divergence theorem?
There are 5 distinct steps in the derivation of the continuity equation:
1. Conservation of mass for EVERY particle-based (i.e), material system.
A material system consists of the SAME particles throughout the observation period.
Thus, for an arbitrary material system with density p, and occupying spatial region [tex]V_{M}(t)[/tex], with volume V(t), we have:
[tex]0=\frac{d}{dt}\int_{V_{M}}\rho{dV} (1)[/tex], where we sum up the masses for the whole spatial region.
The mass conservation principle for material systems is AXIOMATIC in classical physics (it is, as it happens, untrue; a material system under the influence of relativistic effects, for example, may well experience changes in its mass!)
2. Transition from a material system perspective, to a coincident geometric perspective:
A material system, which labels its constituent particles and tracks them meticulously over time is a rather cumbersome way of dealing with the time evolution of a continuum.
Generally, we prefer to use a GEOMETRIC perspective, in that we keep under control and designation a particular geometrical region, IRRESPECTIVE of whether individual particles choose to remain within that region, or choose to to leave (or enter) it.
(We call the material approach "Lagrangian", the geometric approach "Eulerian").
Thus, we are no longer concerned with individual particle quantities per se, like particle density, particle velocity, and so on; rather, we are interested in the evolution of FIELD quantities, i.e, the evolution of the density field and the velocity field.
The field density function, [tex]\rho(x,y,z,t)[/tex], is then related to to the material density distribution as being equal at a particular time t to the density to whichever material particle that happens to be at (x,y,z) at the time t. Time evolution of the density function, then, must be understood as the difference in density of the DIFFERENT particles occupying (x,y,z) at different times. ((x,y,z) itself, of course, must be understood as the centre of a tiny region over which we have averaged quantities).
At any time t, the region occupied by some material system is clearly coincident with some geometrically defined region [tex]V_{G}(t)[/tex], whose surface velocity is defined as [tex]\vec{v}_{s}(x,y,z,t)[/tex]. A fixed geometric region has surface velocity 0 everywhere, and we'll use that in the following.
Thus, (1) may be rewritten as:
[tex]0=\frac{d}{dt}\int_{V_{G}}\rho{dV}(2)[/tex] where with a slight abuse of notation, I have retained dV as designating the (geometric) volume element, and the same letter for material and geometric density functions.
3. DIfferentiation of the integral.
This is given by Reynold's transport theorem, i.e we generally have:
[tex]\frac{d}{dt}\int_{V_{G}}\rho{dV}=\int_{V_{G}}\frac{\partial\rho}{\partial{t}}dV+\int_{S_{G}}\rho\vec{v}\cdot\vec{n}dA(3)[/tex], where S_G is the surface of the region, and dA the area element.
Thus, inserting (3) in (2), we get:
[tex]0= \int_{V_{G}}\frac{\partial\rho}{\partial{t}}dV+\int_{S_{G}}\rho\vec{v}\cdot\vec{n}dA(4)[/tex]
Note that this simply says that the increase of mass within the specified region (first integral) must balance the outward mass flux (second integral).
That this should be equivalent to the mass conservation principle should be obvious.
4. Application of Gauss' divergence theorem.
This is now utilized on the second integral on the left hand side of (4):
[tex]\int_{S_{G}}\rho\vec{v}\cdot\vec{n}dA=\int_{V}_{G}\nabla\cdot{(\rho\vec{v})}dV(5)[/tex]
Adding together the volume integrals we now have, we get by manipulations:
[tex]0=\int_{V_{G}}\rho(\frac{1}{\rho}\frac{D\rho}{dt}+\nabla\cdot\vec{v})dV,\frac{D\rho}{dt}\equiv\frac{\partial\rho}{\partial{t}}+\vec{v}\cdot\nabla\rho(6)[/tex]
where [tex]\frac{D\rho}{dt}[/tex] is called the material derivative of [tex]\rho[/tex]
5.Use of arbitrariness of chosen region.
Now, since (6) is to hold for any, and every region, the integrand has to equal 0 everywhere.
Therefore, since [tex]\rho[/tex] is not, in general zero everywhere, the continuity equation follows:
[tex]\frac{1}{\rho}\frac{D\rho}{dt}=-\nabla\cdot\vec{v}(8)[/tex]
So, as answer to your question:
No, the continuity equation is not merely Gauss' theorem in disguise, but it certainly depends on it for its own validity!
Firstly, wow! You really went above and beyond give me a thoughtful and comprehensive response, so thank you very much. Secondly, I meant to post this in the quantum forum, as that is what I am studying at the moment. Of course having understood the majority of your post, I also see that this will hold for the quantum case where it is continuity of probability current that is being being described by the equations.
So, if we were to make a measurement that violated the continuity equation, could we also say that gauss' divergence theorem has failed? Or could the discrepency arise from somewhere else? I guess this is one of those 'If unicorns existed, what colour would they be?' kind of question, so I'm not sure if it is really a valid question, but I thought I'd put it out there.
No problem. :smile:
Absolutely not. Empiricism has no place in judging the validity of mathematical propositions!
Rather, it would testify either of two things:
a) The measurement was false
b) The measurement is correct, but the conditions required for the appliciability of Gauss' theorem are not present. (I.e, you have a case of misapplication)
Which of these would be the right one in your particular case, I don't know.
yep. Makes sense.
  • · Replies 17 ·
  • · Replies 42 ·
  • · Replies 29 ·
  • · Replies 30 ·
10K
