Calculate Battery Life with 50 Amp Hour Battery
  • Thread starter Thread starter salman213
    Amp Battery
Calculating the battery life of a 50 amp-hour (Ah) battery requires understanding the battery's discharge characteristics and C rating. A simple calculation of 50 Ah divided by a constant 2 Amps yields 25 hours, but this is misleading due to non-linear discharge curves. The C rating, such as C5, indicates the battery's performance over time, and the minimum allowable voltage must also be considered. For accurate calculations, refer to the battery's data sheet for specific discharge information.
  • Understanding of battery C ratings, such as C5.
  • Familiarity with battery discharge curves and their non-linear nature.
  • Knowledge of minimum allowable voltage for battery discharge.
  • Ability to locate and interpret battery data sheets.
  • Research how to interpret battery discharge graphs for various battery types.
  • Learn about different C ratings and their implications on battery performance.
  • Investigate the effects of voltage drop on battery life and performance.
  • Explore resources for finding and analyzing battery data sheets online.
Battery engineers, hobbyists using lead-acid batteries, and anyone involved in battery management systems will benefit from this discussion.
salman213
Hi I was using a 50 amp hour battery and running something which is using 2 Amps all the time..
How would I calculate the time the battery will last ?
Thanks!
50/2=25...
...but depending on the type of battery, 50 amp-hours may not really be 50 amp hours and 2 Amps may not really be 2 amps. These things change as the battery discharges, so depending on how accurate you want to be, you may need to account for them.
If life was only that easy!
You need to get the battery data sheet which will give you the data.
Battery discharge graphs are curves and are not linear therefore you cannot simply divide 50 by 2 to get 25 hours.
The battery you mention is 50Ah but at what C rating is this? For example if the battery is 50Ah at C5 then it will give 50Ah for 5Hours ie 10A per hour. This does NOT mean that you can then say it will give 50A for one hour or 1A for 50 hours.
You will also need to know how low you can allow the battery voltage to drop. All battery discharge data is given down to a specific voltage. For sealed lead acid batteries this is usually down to between 1.6-1.9 V per cell.
If you get the battery manufacturer and model then you should be able to search online for the battery discharge data sheet.
http://www.powerups.co.uk
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 29 ·
