Confirm Gate, Drain, Source in Image
  • Thread starter Thread starter atlbraves49
    Gate Image Source
The discussion confirms the correct identification of the Gate, Drain, and Source terminals in the IRF640N MOSFET. The user sought clarification on the terminal layout, which is validated by the datasheet provided. The heatsink tab is also noted to be connected to the Drain terminal, which is crucial for thermal management in circuit design.
  • Understanding of MOSFET terminal configurations
  • Familiarity with reading electronic component datasheets
  • Basic knowledge of thermal management in electronics
  • Experience with circuit design principles
  • Review the IRF640N datasheet for detailed specifications
  • Learn about thermal management techniques for MOSFETs
  • Explore the differences between N-channel and P-channel MOSFETs
  • Study common applications of MOSFETs in electronic circuits
Electronics engineers, circuit designers, and students studying semiconductor devices will benefit from this discussion, particularly those working with MOSFETs in their projects.
atlbraves49
Just want to confirm i have this correctly..
in the following image:
from left to right, its Gate, Drain, Source ?
it doesn't say on the datasheet
http://www.irf.com/product-info/datasheets/data/irf640n.pdf
Yes that's correct, it's shown in the package outline at the end of the datasheet. Note that the heatsink tab is also connected to the drain.
