Combining exponential distributions
The discussion revolves around combining exponential distributions to determine the probability of at least one event occurring within a specified time frame. Participants explore the mathematical formulation of this problem, particularly in the context of independent random variables representing train arrival times.
  • One participant introduces the problem of combining the density functions of independent exponentially distributed random variables representing train arrival times.
  • Another participant suggests that the probability of both events occurring can be expressed through multiplication of their individual probabilities, but clarifies that the focus is on the probability of at least one event occurring.
  • A later reply proposes a formula for the probability of at least one train arriving by time x, derived from the complement of the probability that neither train arrives.
  • Some participants express confusion over the notation and the interpretation of probabilities, debating the correct formulation of the union of events in the context of time.
  • One participant acknowledges a misunderstanding in their previous posts and attempts to clarify their reasoning, ultimately aligning with the earlier proposed solution.
Participants exhibit disagreement on the interpretation of probability notations and the correct approach to combining the distributions. However, there is a convergence towards understanding the correct formulation for the probability of at least one event occurring, with some participants acknowledging corrections made by others.
Some participants express uncertainty regarding the application of general probability rules to the specific context of time-dependent events, leading to potential misinterpretations of the problem. The discussion reflects a progression of thought and refinement of ideas rather than a definitive resolution.
gnome
Suppose I have several exponentially distributed random variables, each of them representing the probability that some particular event occurs within some amount of time. I can't seem to come up with any intuition as to how to combine those density functions (or distribution functions) to express probabilities about ANY of the events occurring.
To give a concrete example, say the A-train and the B-train arrive on separate tracks and their inter-arrival times are independent of each other, and let [tex]X[/tex] be the continuous rv representing the amount of time until a train arrives. Say the density functions and distribution functions for the two train lines are given by:
[tex]f_a(x) = \frac{1}{4} e^{-\frac{x}{4}} \qquad F_a(x) = 1 - e^{-\frac{x}{4}} \qquad \mbox{ for } x>0 \mbox{, and 0 otherwise}[/tex]
[tex]f_b(x) = \frac{1}{5} e^{-\frac{x}{5}} \qquad F_b(x) = 1 - e^{-\frac{x}{5}} \qquad \mbox{ for } x>0 \mbox{, and 0 otherwise}[/tex]
so the expected time until an A-train arrives [tex]E_a[x] = 4\mbox{ min.}[/tex]
and the expected time until a B-train arrives [tex]E_b[x] = 5\mbox{ min.}[/tex]
and it is easy to determine the probability for an A-train to arrive within any specific amount of time, and similarly for a B-train.
But how can those functions be combined into a single distribution to express the expected time [tex]E_{a|b}[x][/tex] until ANY train arrives, or the probability that ANY train will arrive within, say 2 minutes?
If two random variables are independent then:
P(a,b)=P(a)P(b)
Thus just multiply the distribution functions. You can also easily derive expressions for correlated random variables because you can use linear algebra to diagonalize the random variables and find a linear transformation between the correlated random variables and a new set of independent random variables.
Running helps to clear the cobwebs.
P(a,b)=P(a)P(b)
It's not the joint probability I'm looking for; that would be the probability that both an A-train and a B-train arrive by time x. I guess the probability I want may be called [tex]P_{a \cup \, b}(x)[/tex]. But here's what occurred to me. The probability that any train will arrive by time x is 1 minus the joint probability that (neither an A-train nor a B-train arrives by time x) so
[tex] \begin{align*}<br /> F(x) = P_{a \cup \, b}(x) &= 1 - e^{-\frac{x}{4}}e^{-\frac{x}{5}} \\<br /> &= 1 - e^{-\frac{9x}{20}}<br /> \end{align*}[/tex]
and therefore just taking the derivative of that gives me
[tex] f(x) = \frac{9}{20} e^{-\frac{9x}{20}}[/tex]
which is an exponential distribution with an expectation of 20/9, i.e. the expected arrival time of some train, on either track, is about 2.22 minutes.
That seems plausible. Is it correct?
I don't think your right. Sorry for misreading it earlier. Here is what I think you want:
[tex]P(a \cup b)=P(a-ab)+P(ab)+P(b-ab)[/tex]
and I think (let met think about it though):
[tex]P(a-ab)=P(a)(1-P(b))[/tex]
[tex]P(b-ab)=P(b)(1-P(a))[/tex]edit: This seems to simplify to, P(a)+P(b)-2P(ab)
I don't know what you mean by [tex]P(a), P(b), P(ab)[/tex], etc. I'm talking about the probability that an event a will occur within a specified amount of time x, the probability that event b will occur within that amount of time, and the probability that either event (don't care which) will occur within that amount of time. I may be wrong, but you appear to be thinking about whether a, b, or either event occurs at all, which is a completely different thing. (Where is the element of time in what you are suggesting?)
You seem to be trying to get to the general expression for probability of the union of two events, which is actually
[tex]P(A \cup \, B) = P(A) + P(B) - P(AB)[/tex]
but I don't see how that applies here.
Thanks for the correction.
I'm going to clarify what I was thinking but I guess it turns out you were correct in your previous post. I didn't have much time to think about the problem in my past posts so I ended up not reading clearly and thinking it through enough.Let [tex]X_a[/tex] be the random variable that gives the time train A will arrive and [tex]X_b[/tex] be the random variable that gives the time train B will be arrive. We want to know if either train A or train B or both arived in a time less then t. Therefore we want
[tex]P(X_a<t \cup X_a<t)[/tex]
We should agree from the general expression for probability of the union that:
[tex]P(X_a<t \cup X_a<t)=P(X_a<t)+P(X_b<t) - P(X_b<t \cap X_a<t)[/tex]
Given the distributions are independent we can write:
[tex]F_{a \cup b}(t)=F_a(t)+F_b(t)-F_a(t)F_b(t)[/tex]
[tex]=( 1 - e^{-\frac{x}{4}})+(1 - e^{-\frac{x}{5}})-( 1 - e^{-\frac{x}{4}})(1 - e^{-\frac{x}{5}})[/tex]
[tex]=1-e^{-\frac{9x}{20}}[/tex]
Which is of course what you gave as the answer in your previous post. What I didn't realize is how you arrived at the answer since a few steps were left out.
