Thread Closed
probabilities of duplicates
Share Thread Thread Tools
Mar15-09, 03:39 PM   #1
What is the probability of getting a duplicate of a digit in a randomly generated sequence of four digits?
I would approach this intuitively as follows.
(1.0)(0.1)(0.9)(0.9)=0.081
" (0.1)(0.1)(0.9)=0.009
" (0.1)(0.1)(0.1)=0.001
Sum =0.091
There must be a more efficient and elegant way of doing this but I've not been able to find one. Also, is there a more general formula for a set of n distinct objects each with a probability 1/n of being selected?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar15-09, 03:53 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi SW VandeCarr!
Quote by SW VandeCarr View Post
hmm … what is the probability of not getting a duplicate?
Mar15-09, 04:04 PM   #3
Quote by tiny-tim View Post
Hi SW VandeCarr!
That's included in my calculation. I believe the calculation is correct. The probability of not getting a duplicate for randomly generated n distinct objects is (n-1/n)^n, but duplicates are included in triples, quadruples,etc.
Mar15-09, 04:13 PM   #4
Recognitions:
The probability of not getting a duplicate for randomly generated n distinct objects is (1/n)^n,
sorry, completely wrong
start again
Mar15-09, 04:17 PM   #5
start again
You're too fast. You missed my edit.
Mar15-09, 04:25 PM   #6
Recognitions:
oooh … still completely wrong …
and why is there only one variable (n)?
Mar15-09, 04:54 PM   #7
OK. First, is my calculation correct? If so, is there a general formula for this?
You're correct, there is more than one variable. From a set of N distict objects, a random sequence of n objects is generated. The probability of not getting a duplicate in the sequence of n objects is ((N-1)/N)^n.
Now, let r equal all replications (duplicates, three of a kind, four of a kind, etc) each considered to contain just one duplicate, what is the most efficient way to calculate the probability of a duplicate so defined?
Mar15-09, 05:02 PM   #8
Recognitions:
No, that's the probability of not getting any 0s
Mar15-09, 05:47 PM   #9
Well, if the number of digits is greater then the base then the probability is equal to one.
Mar15-09, 06:09 PM   #10
I don't understand that answer. The objects in the general case aren't necessarily numbers. Each random selection yields one object which may be selected more than once out of n selections. Perhaps the probability is ((N-1)/N)^n-1. Do you know?
My reasoning regarding the probability of getting only a duplicate in four randomly generated digits is:
The first selection can be any digit and therefore has a probability of one.
The second selection has a probability of 0.1 of being the same digit.
The third and fourth selection have a probability 0.9 of not being the same digit.
Since multiplication is commutative, the actual order doesn't matter.
If we consider the probability of getting at least a duplicate, then we need to add the probabilities of getting three or four of a kind.
I don't think the answer is as simple as 1-(0.9)^3.
Mar15-09, 06:40 PM   #11
So we're dealing with base 10.
I Think I get the idea.
Okay. I agree after two digest:
Probability of a repeat 1/B where B is the base
There are now two digest taken. So when we add another diget:
1/(B)+(1/(B-1))*(1-1/B)
As there is 1/B chance of the third digest matching the fist digit, but if the third digit doesn't match the first that leaves (B-1) numbers in the diget left. So the probability of it matching the second digit is 1/(B-1) multiplied by the probability that it didn't match the first digit.
Let P(N) be the probability of a match after N digest then
[tex]P(N)=P(N-1)+(1-P(N-1))*{1 \over B-N+2}[/tex]
and
[tex]P(2)=1/B[/tex]
Mar15-09, 09:32 PM   #12
Actually the argument is counter-intuitive if one is thinking in terms of cumulative probability. For cumulative probability 1-(0.9)^3 is correct. That is, once the marker digit is selected, the cumulative probability that a duplicate will be selected in the next three selections is about 0.271. However, cumulative probability is not the same as sequential probability. The probability that the marker will be matched in any particular one of the next three independent selections is still 0.1 in frequentist theory.
The idea of cumulative probability fits with experience, but an it's entirely different concept than the probability of a single independent event. I don't know the answer to this problem, but it is a problem. Randomized scientific trials use threshold probabilities to determine statistical significance but rarely adjust the significance level for the number of similar trials conducted. If you believe in cumulative probability, scientific trials should adjust these levels or be liable for false positive results.
Mar15-09, 09:59 PM   #13
Which part of my last post do you disagree with and how does this apply to randomized scientific trials. Is there an area of research were these statistics are particularly important? 1-(0.9)^3 is probably an okay approximation if the base is large relative to the number of digits. Since the base is 10 and the number of digest is four, it might be an okay approximation for this problem.
Your formula clearly fails when the number of digits N=10 since it gives a finite probability of no repeats which is impossible with 10 digits.
Mar16-09, 04:10 AM   #14
Recognitions:
uhh? what is the question … getting exactly one duplicate, or getting one or more duplicates?
i assumed from your original post that it was the latter
Mar16-09, 10:18 AM   #15
Quote by John Creighto View Post
The cumulative probability of getting at least one duplicate or at most one duplicate obviously must increase as the number of randomly generated digits increase. For four digits the questions boil down to how many sequences between 0000 and 9999 have at least one duplicate, and how many have at most one duplicate?
For sequential probability, the question is: given an existing digit sequence of n digits with no duplicates, what is the probability that the next digit selected will be a duplicate of one of the previously generated digits? For a generated sequence that already has just one duplicate, the probability that an expanded sequence (by adding more randomly generated digits) will have just one duplicate decreases.
Mar16-09, 11:55 AM   #16
I'm not sure it's a good idea to ask more then one question in the same post. Anyway, you still haven't critiqued the steps in my solution above for the probability of getting at least one duplicate.
Again, I thought I solved this problem.
I'll give this problem a shot later. I think though we should do it in a separate thread, and I think the moderate should make the title of this thread more clear.
Mar16-09, 03:43 PM   #17
You're using different notation than I am. For digits B=N=10 and n is the length of the randomly generated (rg) string. Your formula seems correct for n=2. For n=10 with no duplicates, its clear that the next rg number is a duplicate with p=1.
If your N=n and your B=10 then 1/B-N+2 = 0.5 for N=n=10. I haven't done the full expansion, but the 11th rd digit must be a duplicate (assuming no duplicates in the string n=10) as you have said.
For cumulative probability there are two related questions. I'm including cumulative probability because tiny tim raised the issue. One is the number of 4 digit sequences that contain at least one identical pair (1213, 3333, 4433, 0051, 0110, ect.) The other is the number of 4 digit sequences that contain at most one identical pair excluding triplets and quadruplets.
The title is "probabilities of duplicates" and I'm not giving a tutorial. I'm asking questions because I don't know the answers.
Thread Closed
Thread Tools
Similar Threads for: probabilities of duplicates
Thread Forum Replies
Probabilities Precalculus Mathematics Homework 4
probabilities Precalculus Mathematics Homework 5
Can the probability of an event ever be a transcendental number? Set Theory, Logic, Probability, Statistics 11
probabilities Set Theory, Logic, Probability, Statistics 1
SHM and probabilities - help! Classical Physics 3
