Speed of light constant throughout universe?
The discussion revolves around the constancy of the speed of light throughout the universe, questioning how this has been established given that measurements have not been made beyond the solar system. Participants explore implications for astrophysics, distance calculations, and the nature of light in different regions of space.
  • Some participants question how the speed of light can be considered constant if it has not been measured beyond the solar system, suggesting that this could affect calculations of distances and the age of the universe.
  • Others argue that the successful application of physical laws across vast distances supports the idea that the speed of light is constant.
  • One participant suggests that the equivalence of physical laws in different regions of the universe implies that light behaves the same everywhere.
  • Concerns are raised about the validity of extrapolations made from measurements within the solar system to distant objects, questioning the standards used for such measurements.
  • Some participants mention the use of standard candles and spectral analysis to determine distances to stars, indicating methods of measuring without direct travel.
  • There is a discussion about whether distant atoms are fundamentally the same as those on Earth, with some arguing that energy levels observed in distant atoms align with terrestrial measurements.
  • Speculations arise about the possibility of different physical laws or constants in other regions of the universe, including the notion of dark energy affecting measurements.
  • Some participants express skepticism about unprovable hypotheses regarding the nature of distant matter, emphasizing the need for strong evidence to support such claims.
  • Questions are raised about whether the speed of light could have varied in the past, with references to theories suggesting it may have been different.
Participants generally agree that the speed of light has not been measured outside the solar system, but there is significant disagreement regarding the implications of this and the validity of extrapolating measurements to distant objects. Multiple competing views remain on the constancy of physical laws and the nature of distant matter.
Limitations include the lack of direct measurements of the speed of light beyond the solar system and the dependence on assumptions about the uniformity of physical laws across the universe. The discussion also touches on unresolved questions regarding the nature of distant atoms and the potential for varying physical constants.
M31
Hello all,
I have just discovered (and joined) the Physics Forums, and want to ask a question which I have been wondering about for a long time (please forgive me if this has been covered here before):
How do we know that the speed of light is constant throughout the universe if we have not been beyond the edge of the solar system yet (I don't know where the Pioneer probes are nowadays, so that's why I say that)?
I can see how one would base a result from experiments between the Earth, and say the Moon, Mars, etc... but how do we know how light behaves beyond the solar system? In the event (only for the sake of discussion) that light behaves altogether differently in other regions of space (I couldn't even begin to hazard a guess why), wouldn't that throw off calculations of distances and possibly the age of the universe, by some degree?
If this has been discussed elsewhere, can someone please post references?
Thanks for your time (no pun intended),
M31
That would throw off virtually every bit of astrophysics. The fact that our physical extrapolations work very well wherever we look validates that extrapolation.
I agree with you on priniciple, but I guess what I am looking for, among other things, is a 'what are we using for a standard' type of avenue.
To be more precise, how distant have the extrapolations been applied, and held up? If the speed of light cannot be 'tested', say for example, from the nearest star outside the solar system, wouldn't the tests be valid only for the distances that we have so far physically reached?
Thanks for your reply...
M31
I agree that we have not measured the speed of light outside solar system. One way to look a it is the equivalence or symmetry of the usniverse, that is we believe the every spot of the universe should be the same in physical essence. For example, from Earth we believe every direction is equivalent, north direction south direction etc.
In universe expansion, we think every spot is equivalent. Every spot can be considered at rest roughly, but only the relative sidstance is increasing. It could be one way to accept of 'c'.
We will continue to believe it until an obvious confilicting evidence comes up.
The most distant quasars are use to measure deviations of physical constants, especially the fine structure constant.
v2kkim, Ich,
Thank you for the replies. I find this material absolutely fascinating.
So, if you'll allow, let's dig a little further.
Say I am in a spacecraft that can travel at 1x the speed of light, and it takes me 7 days (just for the sake of discussion) to get to the nearest star. I can now derive the distance to this particular star based on 1x speed of light x elapsed time, because I physically arrived there. I 'created' an origin and an endpoint for my journey.
What I am having trouble resolving is how we are able to measure the distance to a distant object, if we have never been to that same distant object to justify the calculation.
I am almost certain I am missing something that would make it all fit into place, but I don't know what that piece is.
Thanks,
M31
So what your asking is how do we know things are as far away as we think they are?
Simply put, yes.
M31 said:
v2kkim, Ich,
M31
Your question is more related to SciFi like Star Trek, my favorite, where they know about their travel and location very well. Ideally we can record our velocity continuously as we change speed and direction, in that way we can have our velocity log and a hand carried clock, so we can calculate our location, but as time goes on the error might accumulate so calibration of the speed log should be needed. Also some known stars or galaxies might be a guidance. This method will apply for a short distance travel, in case you travel really far away then your past travel log book need to be update considering universe expansion. Here I did not include the relativistic effect of length contraction.
we can tell how far away stars are by using what they call a standard candle
if we know how bright it is we can know how far away it is . And they use a spectrometer to get the Spectral lines so they can figure out what element is making up that light. This is how helium was discovered they looked at the sun and saw spectral lines that they had never seen before. and i think photons dim proportional to the inverse square law.
http://en.wikipedia.org/wiki/Cosmic_distance_ladder"
I disagree with that. The speed of light is essentially the ratio of the strength of magnetism to electricity. If you alter the speed of light, you alter (among other things) the energy levels of atoms, but we know through spectra that distant atoms have the same energy levels as terrestrial atoms.
how do we know that those distant atoms are atoms we have have on our periodic table?
They are the same because they have the same energy levels.
what if it is dark energy emitting the same energy level but different composition then what we think it is.
Some of those elements on our periodic table were first discovered outside of our planet. Look up where helium got its name.
If it's emitting energy, then it's hardly 'dark'.
If you want to believe stuff outside of earth, or outside of our solar system, is somehow fundamentally different than the matter we know of, you'll have to come up with a very good reason for it. Because so far this assumption has proven itself valid as many times as we've had opportunities to check it.
Unprovable 'what ifs' only lead to the old Cartesian doubt formula. "What if the entire world is just a dream?". That'll get you absolutely nowhere as far as Science is concerned.
k if u would have read above i already said how helium was discovered. and u think all energy is in the visible spectrum what about gama rays , x-rays, how about infared i think we get the point, ok i give this one 2 u , ur right to the best of our knowledge
it is matter that we know of .
We do not know what energy levels have distant atoms - we know only that proportions are the same. For example doppler effect shifts apparent spectral lines and the same does gravity.
Even more from relativity principles one can conclude that change in speed of light is locally undetectable.
Can you determine if the speed of light was always the same.
Could it have been faster or slower in the past?
K. there has been a lot of talk here about elements and things that aren't really relative to the original queston.
He was asking how do we know that the distance in light years is the true distance. For instance, if we know through all our computing with standard candles and whatnot that we have measure that Star S is X light years away. We have the distance determined to be X light years. The problem is that a light year is really a quantity of time, not distance. We have to use light years to measure distance of far away things because we cannot measure the distance by other means. Light years suffices because it correlates to distance through equation because the speed of light is invariant. So the point is do we know for sure how many Kilometers (a measure of distance) Star S is away from us?
We cannot know for sure. The speed of light does not vary, meaning at any place in space the speed of light is C. However, we know that the speed of light is relative if viewed from another position in space. This means that in different areas of space a light year may be a shorter or longer physical distance.
  • · Replies 25 ·
  • · Replies 64 ·
13K
  • · Replies 19 ·
  • · Replies 93 ·
  • · Replies 45 ·
  • · Replies 42 ·
  • · Replies 36 ·
