Magnetic monopoles, electric field lines and equipotential surfaces
This discussion addresses the implications of magnetic monopoles on the representation of magnetic fields and the definitions of electrostatic fields. It establishes that if magnetic monopoles existed, the magnetic field (B-field) could not be expressed in terms of a vector potential (A). The electrostatic potential (Φ) is defined using the equation Φ(r) = (1/4πε₀) ∫(ρ(r')/|r - r'|) dV', and field lines indicate the direction of a positive test charge in an electric field. Field lines and equipotential surfaces generally intersect at right angles, as the gradient of the potential is perpendicular to the equipotential surface.
  • Understanding of magnetic fields and vector potentials
  • Knowledge of electrostatics and electric fields
  • Familiarity with the concept of electrostatic potential
  • Basic calculus, particularly gradient and integral concepts
  • Study the implications of magnetic monopoles on electromagnetic theory
  • Explore the mathematical derivation of electrostatic potential using Gauss's Law
  • Investigate the relationship between electric field lines and equipotential surfaces
  • Learn about the properties of conductors in electrostatic equilibrium
Students of physics, particularly those focusing on electromagnetism, educators teaching electrostatics, and researchers exploring theoretical physics concepts related to magnetic monopoles.
wam_mi
(i) Explain why it would not be possible to write the magnetic Field (B-field) in terms of a vector potential (A) IF magnetic monopoles existed.
(ii) For an electrostatic field (E-field), define the electrostatic potential (Fi), and explain CONCISELY what is meant by a field line and an equipotential surface.
(iii) At what angle do field lines and equipotential surfaces generally intersect? Briefly explain your answer.
Please help me with the three questions at above.
Cheers guys!
for (ii)
[itex]\phi(\vec{r})=\frac{1}{4 \pi \epsilon_0} \int_{V'} \frac{\rho(\vec{r'})}{|\vec{r}-\vec{r'}|} dV'[/itex]
a field line indicates the direction in which a small positive test charge would move it it were placed in the field.
an equipotental surface is just as it sounds - a surface on which the potential is equal at all points. can you prove that?
consider a conductor surface with normal [itex]\mathbf{\hat{n}}[/itex], you know [itex]\vec{E}=-\nabla \phi(\vec{r})[/itex], so [itex]\nabla \phi(\vec{r})[/itex] points in what direction..., and [itex]\vec{dr}[/itex] on the equipotential surface points in what direction?
now consider [itex]d \phi[/itex] - why would it be 0 if you are on the surface?
actually i just realized that the above argument can be used to answer (iii) as well , just start by assuming [itex]d \phi=0[/itex] this time
  • · Replies 22 ·
