Help on Electric Field Calculations for Test Preparation
The discussion revolves around electric field calculations, specifically involving charge distributions such as line charges, spherical shells, and conducting sheets. Participants are preparing for a test and seek clarification on their approaches and calculations related to these topics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the integration methods for calculating electric fields from line charges and spherical shells, questioning the setup of their integrals and the assumptions made about distances. There are also inquiries about the application of Gauss's law and the interpretation of charge density.
Some participants have provided feedback on each other's calculations, suggesting corrections and clarifications regarding the integration limits and the expressions used. There is an ongoing exploration of the correct application of formulas, with no explicit consensus reached on the final answers.
Participants are working under the constraints of preparing for a test without direct access to instructors, leading to a reliance on peer feedback for verification of their methods and understanding.
mmmboh
Hi I have a test next week and am currently on spring break so I don't have a teacher to ask for help, I just want to confirm that some of these answers are correct and get some help for others.
1. A line with a charge of density -2uC is on the x-axis starting at point x=1m to x=3.5m. Find its charge density and derive an expression for the magnitude and direction of the electric field at a point situated at x=-1.5m.
Ok so here's what I did:
E=[tex]\int[/tex](KDQ)/r^2
I did [tex]\lambda[/tex]=dQ/dL and dQ=(Qdx)/2.5 (2.5 is the length of the line)
I took the limits to be 1 to 3.5, and r^2=2.5^2=6.25
So E=KQ/(2.5x6.25)[tex]\int[/tex]dx ...with limits 1 to 3.5
so E=KQ/15.6 (3.5-1), the final answer I got was 2.88x10^4 N/C, and the direction is left.
Is that right? if it isn't what do I change?
2. An insulating spherical shell with an inner radius 0.1 cm and outer radius 0.3 cm carries a total charge of 20 nC. Use Gauss's law to find an expression for the electric field at a distance r=0.08cm, r=0.2cm, r=0.4cm.
So what I did was [tex]\phi[/tex]=[tex]\int[/tex]EdA = Qin/E0...integral of dA is A and A=4[tex]\Pi[/tex]r^2...
So then I did E=20nC/(4[tex]\Pi[/tex]r^2E0)...and I plugged in the different radii...however this is wrong, or most of it anyway, can someone help please?
3. An arc length with a length of 6 cm and a radius of 3cm carries a uniform charge of 10nC. Derive an expression for the magnitude and direction of electric field at the center.
I don't know what to do for this one. Am I suppose to integrate? like E=[tex]\int[/tex](KdQ)/r^2...
Thanks a lot for any help :)
For a point at -1.5 x, call it P, you have an integral that looks like k*dq/r2 = k*λ/r2*dx
where λ = c/l = 2 μC /2.5 m.
and r = (2.5 +x)
So don't you want to integrate k*λ/(2.5 + x)2*dx from 1 to 3.5?
Ok so the integral is [tex]\int[/tex]K[tex]\lambda[/tex]dx/(2.5+x)^2 from 1 to 3.5.
Which becomes -K[tex]\lambda[/tex]/(2.5+x) from 1 to 3.5. And so the final answer is 8.57 x 10^9 C/m to the left?
But why is r (2.5 + x)?...is it because x=-1.5 and the start of the line is at 1, and the difference is 2.5...and then x is just a place where it could be on the line? I am confused :S
That's right. r is the displacement function from the point that you are measuring to the closest dq that you are going to integrate. So in the equation for the E field you have
dE = k*λ/r2*dx
But since r is a function of x, as in r(x) = (2.5 + x)
Thanks :)...how bout this one:
Two perpendicular conducting sheets with area 2m^2 each. One has a charge of +10uC and the other +30uC uniformly spread over their surfaces. Find the magnitude of the electric field at the point (0.4m, 0.5m) from the corner. Neglect the end effects.
So what I did was E=[tex]\sigma/2E0[/tex] (Sorry I couldn't find the absolute not symbol)
So then I found [tex]\sigma1[/tex] = 15uC/m^2, and [tex]\sigma2[/tex]=5uc/m^2, and I plugged them both into the equation E=[tex]\sigma/2E0[/tex] and then I squared both of them and added them together, and then I square rooted it to find the magnitude...and I neglected the points (0.4m, 0.5m)...the final answer I got is 9.18x10^4 N/C. Did I do this properly?
I have a test Monday, and am on spring break so I have no one to ask, help is much appreciated :)
Looks like a good method.
Your squares are 1.4m on a side, so the .4,.5 coordinate looks like you can rely on the construction that the E field from both components can be given by:
E = σ/2εo
Taking the RSS of 5 and 15, in x and y, I get 15.5μC/2εo
Sorry I don't understand. The square is 1.4m on both sides? are you talking about a gaussian surface, if so why 1.4?...and what does RSS mean?
2m2 means 1.4 m on a side.
Root Sum of the Squares is shortened to RSS.
Ok I did:
[tex]\sigma1[/tex]=10uC/2m^2=5uC/m^2
and [tex]\sigma2[/tex]=30uC/2m^2=15uC/m^2
and then I plugged them into the equation E=[tex]sigma/(2εo)[/tex]
So E1 I got is 2.83x10^11 and E2 is 8.48x10^11
And then I RSS'd them and got 8.94x10^11 N/C...it's a little bit different from yours, but I think it's right?
mmmboh said:
Ok I did:
Probably, because mine was in error, I typo'd 15.5 when I meant 15.8.
But it look's like a factor of μ is missing in your final magnitude.
Ah, thanks a lot for the help! :)
  • · Replies 16 ·
