What is the truth about photons and their mass?
  • Context: Graduate
  • Thread starter Thread starter ImAnEngineer
    Mass Photons
The discussion revolves around the nature of photons and their relationship to mass, particularly focusing on whether photons can be considered to have mass given their energy and the implications of Einstein's equation E=mc². Participants explore concepts related to rest mass, relativistic mass, and the definitions of mass in the context of physics.
  • Some participants argue that photons do not have rest mass but may have a form of mass related to their energy, as indicated by E=mc².
  • Others propose that the distinction between "rest mass" and "relativistic mass" leads to differing interpretations of whether photons can be said to have mass.
  • One participant suggests that if mass is related to inertia, then photons would imply infinite mass since they cannot be accelerated.
  • Another viewpoint is that while photons have energy, this does not equate to having mass in the traditional sense, as photons can disintegrate into massive particles but do not possess mass themselves.
  • Some participants mention the Doppler effect and gravitational effects on photon energy, suggesting that these phenomena could imply changes in a photon's effective mass.
  • There is a contention regarding the applicability of certain equations to photons, with some arguing that the formula m = m0 / sqrt(1-c²/c²) is not valid for massless particles like photons.
  • One participant emphasizes that the definitions of 'relativistic mass' and 'rest mass' were clarified with the development of special relativity, suggesting that the debate may stem from misunderstandings of these definitions.
Participants generally do not reach a consensus, with multiple competing views remaining on the nature of mass as it relates to photons. The discussion reflects a variety of interpretations and definitions of mass, leading to ongoing debate.
Participants express confusion regarding the definitions and implications of mass in relation to photons, highlighting limitations in understanding the nuances of relativistic physics and the varying interpretations of mass in different contexts.
ImAnEngineer
I had a discussion with my physics teacher. He claimed that photons have mass (although no rest mass), since they have energy and E=mc². I argued that having energy isn't the same as having mass, but that energy could be converted into mass which is a different thing (e.g. a photon can disintegrate into a positron-electron pair which have mass, but that doesn't mean the photon itself had mass). My second argument against the claim that photons have mass, is that (if v=c): m = m0 / sqrt(1-c²/c²) = 0 / 0 which is undefined.
Who is right?
Personally, I would favour the second view, although I don't think anyone is really wrong. You just have differing views, where you have two concepts called "(total) energy" and "mass" and he has two concepts called "rest mass" and "relativistic mass" (which is related to your total energy divided by c^2).
There are arguments for both approaches: on one hand they have different units; on the other hand, in many ways objects with higher energy behave like they are in fact more massive (e.g. you can write F = m a where m = m0 γ is the relativistic mass and m0 the rest mass, for the parallel (or was it perpendicular?) component of the force and acceleration).
Just my 2 cents here, perhaps others disagree.
Ask your teacher what he means by "mass."
Does it have something to do with inertia? If mass has something to do with inertia, then photons must have infinite mass, since you cannot accelerate them at all. Does that seem meaningful?
Does it have something to do with gravity? Photons do cause curvature of spacetime, true... but the curvature they produce is significantly different from that of a mass E/c^2 at rest, and you would get completely wrong ideas about it if you tried to plug E/c^2 into F=Gmm/r^2, for instance.
Yes
Not really.
Moreover, he mentioned de Broglie wavelength:
[tex]\lambda=\frac{h}{mc}[/tex]
Then
[tex]m_p_h_o_t_o_n=\frac{h}{\lambda c}= 3.97 * 10^-^1^9 kg[/tex] if the wavelength is 500nm?
I also asked: do photons with different frequencies have different mass since E=hf?
He answered yes.
If the mass of a photon however is either 0 or infinite, then there shouldn't be any difference in mass. (infinity + a little bit is still infinity). Am I right?
I'm quite confused right now. Please enlighten me :P .
You may want to start by reading the FAQ in the General Physics forum.
Zz.
Zz.
I read it now. What is in there is exactly what I thought!
So my physics teacher sucks? :P
Zz.
By the way, this link in the FAQ is broken:
You can read more about this at the Usenet FAQ.
Does it have something to do with gravity? .
First, accelerating a photon itself is difficult, but you can accelerate a particle or object that emits photons (like a radioactive source), and you will find that the forward emitted photons have higher energy (doppler shift) even though their velocity has not changed. So if the photon energy has increased, and the velocity has not increased, then its relativistic mass has increased.
Second, If you use an iron-57 source which emits 14.4 keV photons with a very narrow linewidth, and put it on the roof of a building, and measure the energy of these photons at ground level, you will find that the photon energy has increased due to the gravitational potential change. This is called the Mossbauer Effect experiment, which was done in 1959 at Harvard by Pound and Rebka.
this is a long standing debate, with advocates on both sides of this issue. photons have no rest mass. however, E=MC2 does indeed imply that energy and mass are interchangeable, thus implying that the energy of photons does indeed represent a certain quantity of mass, which is born out by the fact that photons can impart momentum. the resolution revolves around (as mentioned above) the definition of mass used in the discussion.
So would a calculation as I posted in post#4 make sense?
Yes, your teacher sucks at physics if they think that the mass of a photon is given by m = E / c^2.
My opinion is that the concept of "relativistic mass" is pointless, and I don't use it myself. Note that the formula E=mc² for photons isn't even a derived result. It's the definition of m.
It does make sense to think of a photon's energy as a "mass" expressed in different units. Consider e.g. a box that contains one photon, endlessly bouncing around between its walls. If you put this box on a (ridiculously sensitive) scale, you will see that it weighs more than an identical box that's empty. You can think of this as a consequence of the photon being blueshifted by gravity on the way down, and redshifted on the way up, so when it hits the floor it has more momentum than when it hits the ceiling.
The same box will also be slightly more difficult to accelerate than an empty box, for pretty much the same reason. Just replace the word "gravity" above with "acceleration".
And yes, the amount of momentum and energy gained during the trip from the ceiling to the floor depends on the energy of the photon, so a photon with higher energy changes the "mass" (as measured by the scale) by a larger amount.
That particular formula is for massive particles, so it doesn't apply. The formula that holds for all particles is
[tex]E^2=\vec p^2c^2+m_0^2c^4[/tex].
When [itex]\vec p=m\vec v=\gamma m_0 \vec v[/itex], the right-hand side reduces to [itex]m^2c^4[/itex], but [itex]\vec p=\gamma m_0 \vec v[/itex] only holds for massive particles.
No, it is not a "long-standing debate". The definitions of 'relativistic mass' and 'rest mass' were made quite clear when special relativity was developed, as well as the fact that the 'm' in E=mc^2 is rest mass and nothing else.
I don't see where the 'debate' would be. Either you've understood SR, including its definitions, or you haven't.
There are those who understand that the definitions of relativistic mass and rest mass are only definitions, and then there are those who insist that relativistic mass is incorrect. This is where the debate originates.
Well that 'm' in that equation surely can be something else than the rest mass, since you did not emphasize that the energy means the rest energy by writing lower index E_0.
I understnd that it is slightly belongs to the 'Beyond the Standard model'
But among different definitions of mass we should use the one which still correct when we go deeper and deeper.
So, mass of all prarticles is 0 and the observed mass is a result of interaction of these massless particles with the Higgs condensate. So, no particle can be observed in it's own rest frame. Hence, only reltivistic definition of mass in valid on the long run.
It is clear to me that a photon has no rest mass. But can anyone come up with a watertight argument that it has no relativistic mass? And that calculating the mass by m=E/c² is wrong? I want to know how I can convince my teacher I am right :) .
Thank you
Thank you
This really depends on your definition of "relativistic mass".
Once properly defined, then you can probably answer your own question [with your definition].
To me, the real [physically-interesting] issue is likely
how would one use or misuse such a quantity.
You are not right here, since photon has relativistic mass.
Trying to compute rest mass with [itex]m_0=E/c^2[/itex] would be wrong, while [itex]m_0=0[/itex] is right.
Computing relativistic mass with [itex]m_{\textrm{rel}} = E/c^2[/itex] is right.
Here you are right, since "the mass" usually means the rest mass, and we are supposed to use the notation [itex]m=m_0[/itex] (right), and not the non-standard notation [itex]m=m_{\textrm{rel}}[/itex] (wrong).
So [itex]m=E/c^2[/itex] would usually mean [itex]m_0=E/c^2[/itex] which is wrong.
alxm - a rather terse and closed position for you to take here. the debate revolves around the basic concept of relativistic mass as applied to photons, and there are several threads about this in the archives. many people deny relativistic mass outright, while many others see merit in its application to photons. there is no reason to assume any kind of fixed opinion in QM, since even you must agree that nobody understands the underlying reality. we are all in kindergarten as far as i am concerned.
I wonder how did they eventually built the H-bomb with this controvesy.
:rolleyes:
Relativistic mass already had another name: total energy. Why do people want to create another name?
:rolleyes:
The controversy was helpful. It meant that people who were not clever enough to see through it would drop out in college. :biggrin:
Okay, so then what are different ways to define relativistic mass?
Okay, so [itex]m_r_e_l=E/c^2[/itex] can be used to compute the relativistic mass of photons.
What other name?
ImAnEngineer said:
What other name?
The relativistic mass of some object is simply the total energy of the object divided by [itex]c^2[/itex], so they are almost the same thing. There is the concept which originally has the name "energy", and then it is given other name "relativistic mass" in a redundant manner. Some people believe that it is a useless alternative name for a concept which already had a name.
Ah ok, thanks! Now I understand.
Thank you
Everyone agrees a photon has no "rest mass". Everyone agrees a photon has "relativistic mass". What they disagree over is whether it has "mass", i.e. does "mass" mean "rest mass" or "relativistic mass"? This is just convention, but there's no convention that everyone agrees with. It seems most professional experts use "mass" to mean "rest mass" (and never refer to "relativistic mass"), but some don't.
ImAnEngineer said:
What other name?
Er, "relativistic mass". "Relativistic mass" and "total energy" are two names for the same thing (in different units). Why have two names when one will do?
I agree with the science and understand the terminology here. Just curious whether the "originally" is historically correct - after all, isn't energy in special relativity a new thing? It only approximates the Newtonian one at low speeds, and I've heard it said that special relativity shows that "energy" is not conserved, but physicists like "energy" conservation so much, they redefined "energy" so that it is still conserved.
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 48 ·
  • · Replies 29 ·
