Thread Closed
total internal reflection
Share Thread
Mar19-09, 08:23 AM   #1
Light is incident normally on the short face of a 30-60-90 (degree) prism. A drop of liquid is placed on the hypotenuse of the prism.
If the index of the prism is 1.68, find the maximum index that the liquid may have if the light is to be totally reflected.
2. Relevant equations
sin ik = n1/n2
3. The attempt at a solution
sin 60 = n1/1.68
n1= 1.45
it said that my answer is close enough only differ in significant figure. however, they didn't accept my answer. anyone how to solve this problem?? thanks
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Mar19-09, 08:43 AM   #2
Mentor
Your answer looks fine to me.
Mar19-09, 09:48 AM   #3
Quote by Doc Al View Post
i was doing this problem in mastering physic..
and it turned out
"Very close. Check the rounding and number of significant figures in your final answer."
any clues about using mastering physics regarding to rounding the answer???
Mar19-09, 06:34 PM   #4
Mentor
Since the calculation gives 1.45492..., it is possible that Mastering Physics made a rounding error and thinks it should be 1.46.
Mar20-09, 06:52 AM   #5
Quote by Redbelly98 View Post
OMG..!!
thanks..
it works..
mastering physics sometimes is really killing me with its rounding thingies.. :(
Mar20-09, 07:13 AM   #6
Mentor
Good catch, RB!
Quote by marpple View Post
You will probably not be surprised to learn that you are not the first to complain about problems with mastering physics.
Mar20-09, 07:36 AM   #7
Mentor
It was just a hunch.
If sin(60°)=0.8660... is rounded to 0.87, one gets 1.4616→1.46
Mar20-09, 07:47 AM   #8
Mentor
That's where I was going to go. I wondered if the 60° was meant to be "exact" or really to only 2 sig figs (or 1 ). But if that were true, then the answer should have been rounded to 1.5, which won't fly with Mastering Physics...
Mar20-09, 08:21 AM   #9
alright... another questions.. still regarding to internal reflection.. :)
A light ray in air strikes the right-angle prism shown in the figure (Intro 1 figure) angle B=32.0. This ray consists of two different wavelengths. When it emerges at face AB, it has been split into two different rays that diverge from each other by 8.50 degree .
Find the index of refraction of the prism for each of the two wavelengths.
so far,, what i did is...
for wavelength one...
n1 sin theta1 = n2 sin theta2
1 . sin 90 = n2 . sin 12
n2 = sin 90 / sin 12 = 4.809
for wavelength two...
1 . sin 90 = n2 sin (12+8.5)
n2 = sin 90/ sin 20.5 = 2.85
anyone knows where the mistakes are...??
thanks
Mar20-09, 08:27 AM   #10
Mentor
This problem has nothing to do with total internal reflection, just plain old refraction. The first refraction is trivial--the rays pass straight through. You only have to worry about the second surface, where it goes from glass to air. What's the angle of incidence at that surface? What are the angles of refraction?
Mar20-09, 08:28 AM   #11
Mentor
Yes, they (Mastering Physics) have botched this one. It's not uncommon in physics problems to give nice round figures and assume they're "exact", as they seem to have done with the prism angles here.
A commercial prism will typically have better than 0.05 degrees (and sometimes better than 0.01 degrees) tolerance. Not that introductory physics students should be expected to know that!
Mar20-09, 08:37 AM   #12
ahh..i thought it was total internal reflection since the ray coming in 90 degree,, but.. for total internal reflection 90 degree should be for the angle of refraction.
so, we dont need to consider from air to glass?
yess...yess...
blame mastering physics
Mar20-09, 08:40 AM   #13
Mentor
Nothing to consider. The ray passes straight through (as shown in the diagram) since the angle of incidence is 0 degrees.
All the action takes place at the glass to air surface.
Mar20-09, 08:41 AM   #14
so, for the first wavelength
the angle of incidence is 32 degree, and the angle of refraction is 12 ??
for the second wavelength
the angle of incidence is 32 degree, and the angle of refraction is 20.5 ??
am i on the right track??
Mar20-09, 08:49 AM   #15
Mentor
Your angles are off. Remember that the angles are measured from the normal to the surface, so you have to figure them out.
Mar20-09, 08:51 AM   #16
which one is not correct??
the angle of the incidence or the angle of refraction??
Mar20-09, 08:52 AM   #17
Mentor
None of them are correct.
Thread Closed
Similar Threads for: total internal reflection
Thread Forum Replies
Total Internal Reflection Introductory Physics Homework 1
why is there total internal reflection General Physics 4
total internal reflection Introductory Physics Homework 1
Reflection,Refraction,Total Internal Reflection,Diffraction Introductory Physics Homework 2
