How Much Na2S2O3 Is Needed for Titration in This Redox Reaction?
  • Thread starter Thread starter Maharg
    Redox Titration
The discussion revolves around a homework problem involving the titration of iodine liberated from a sample of bleaching powder (Ca(OCl)Cl) using sodium thiosulfate (Na2S2O3) in a redox reaction. Participants explore the calculations necessary to determine the volume of Na2S2O3 required for the titration, addressing the stoichiometry of the reactions involved.
  • Homework-related
  • One participant outlines the reaction between bleaching powder and iodide, providing a stoichiometric equation and initial calculations for the amount of chlorine in the sample.
  • Another participant agrees with a similar calculation for the volume of Na2S2O3 needed, arriving at a slightly different value.
  • A third participant questions the accuracy of their calculations, suggesting that not all chlorine in the bleaching powder participates in the reaction, indicating a potential misunderstanding of the problem.
  • Further discussion includes a suggestion to reconsider the approach by focusing on the molar mass of Cl- and the molecular weight of Ca(OCl)Cl to find the moles of Cl- directly.
  • Participants express uncertainty about the correct method to account for the percentage of chlorine that reacts, leading to confusion about the calculations.
Participants do not reach a consensus on the correct approach to the problem, with multiple competing views on how to account for the chlorine's participation in the reaction and the calculations involved.
Participants note potential limitations in their understanding of the problem, particularly regarding the percentage of chlorine that reacts and the implications for their calculations. There is also uncertainty about the correct stoichiometric ratios to apply.
Maharg
Bleaching powder, Ca(OCl)Cl, reacts with iodide in acidic medium according to the equation:
OCl– + 2 I– + 2 H3O– ---> I2 + Cl– + 3 H2O
How many millilitres of 0.0645 M Na2S2O3 are required to titrate the iodine liberated from a 0.6028 g sample of bleaching powder containing 10.50 % (w/w) Cl ?
I2 + 2S203 --> 2I- + S4O6
I have already submitted an answer for this assignment, and this was one of only 2 questions I got wrong, we can do a second submission so I went to figure this one out.
I think this is where I went wrong.
I Figured out the Cl- moles by: g Cl/0.6028 g = 0.01050
0.063294 g Cl / 35.453 g/mol = 1.78529 mmol
I think I may have done that wrong, but from that.
From mol Cl- I used 1:1 ratio of original reaction to get mol I2
Mol I2 in second reaction are 1/2 mol S203
mol S2O3 = 3.57058641 mmol
Then calculated mL needed.
V = 3.57058641 mmol/0.0645 M
= 55.4 mL
Any suggestions?
None :wink:
I got 55.3 mL, close enough.
Hm.. that's odd then. The computer usually gives part marks when we're close.
Hm, could be we are both wrong. It is 10.5% of Ca(OCl)Cl. Part of the chlorine is not taking part in the iodine oxidation. I have concentrated on your solution, instead of reading the question
Would I just divide it by 2? So only 1/2(1.785 mmol Cl) take place in the reaction?
Ah, possibly I'm going about it the wrong way, can I instead just avoid the w/w of Cl?
0.6028 g / MW Cl-/ MW Ca(OCl)Cl = mol Cl-
Does anyone know, I'm really lost in the solution.
17K
9K
