How do i find electric field of a sphere?
The discussion revolves around calculating the electric field of a solid sphere with a specific charge density and a hollowed-out region. The original poster presents a scenario involving a solid ball with a radius of 5 cm and a negative charge density, along with a hollow spherical space within it. The points of interest for the electric field calculations are specified as points A, B, and C, with particular focus on point C where confusion arises regarding the expected outcome.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply Gauss's law to determine the electric field at various points, considering the contributions from both the solid ball and the hollowed-out region. They express uncertainty about the calculation for point C, questioning why their result differs from the expected answer. Other participants suggest considering the electric field outside the hollow sphere and using the concept of treating the charge as concentrated at the center.
Participants are actively engaging with the problem, exploring different interpretations of the electric field calculations. Some guidance has been offered regarding the application of Gauss's law and the treatment of the charge distribution, but there is no explicit consensus on the resolution of the confusion surrounding point C.
The original poster's calculations are based on the assumption that the electric field inside the sphere can be derived from the charge density, but they encounter difficulties when applying this to point C, which is at the center of the larger sphere. There is a suggestion to consider the electric field outside the imaginary hollow sphere, indicating a potential misunderstanding of the applicable formulas.
Dell
we have solid ball with a radius of R=5cm and a charge density of "rho"=-3C/m3,
inside this ball, we make a hollow ball shaped space with a radius of R/3 with its centre at 2R/3 from the centre of the big ball.
diagram below
http://picasaweb.google.com/devanlevin/DropBox?authkey=Gv1sRgCL_4l4PpvP_YsQE#5314956645280048530
what is the electric field at point:
A-on the leftmost point of the hollow
B-on the top point of the hollow
C-at the centre of the big ball
these are all my calculations, but i am only stuck with C, so if you don't fell like going through the whole story,skip to the last step (4)
what i did was the following:
my workings:
http://picasaweb.google.com/devanlevin/DropBox?authkey=Gv1sRgCL_4l4PpvP_YsQE#5315181847071965298
i say that my field is the total of 2 fields, one of the original ball, and one of the "imaginary hollowed out ball" (which has a density equal to the negative of the density of the big ball)
1) i chose a gauss surface as a sphere, after my calculations i get : E=([tex]\rho[/tex]r/3[tex]E[/tex]0)
i will use this expression throughout my calculation changing the radius every time
2) for point A, i can say that the field in the y and z axis is 0 because of the symetry of the point.
as for the axis:
Ex=([tex]\rho[/tex]R/3[tex]E[/tex]0) - ([tex]\rho[/tex](R/3)/3[tex]E[/tex]0)
EAx=(2[tex]\rho[/tex]r/9[tex]E[/tex]0)
3) for point B, z axis is still 0 because of symetry
Ey=([tex]\rho[/tex](sqrt(5)R/3)/3[tex]E[/tex]0*sin(26.565)) -([tex]\rho[/tex](R/3)/3[tex]E[/tex]0) = 0
Ex=([tex]\rho[/tex](sqrt(5)R/3)/3[tex]E[/tex]0*cos(26.565)) - 0 =
EBx=(2[tex]\rho[/tex]r/9[tex]E[/tex]0)
4) for point C i say that since it is exactly in the centre of the big ball, the big ball's field at C is equal to 0, because of perfect symetry and because R=0, so the total field at point C is only the field of my hollowed out imaginary ball,
because of the symetry, the imaginary ball too has 0 field on y and z axis so i only care about x
ECx=([tex]\rho[/tex](2R/3)/3[tex]E[/tex]0)
ECx=(2[tex]\rho[/tex]r/9[tex]E[/tex]0)
HOW CAN THIS BE??
for A, B i understand that it is possible that the field is the same, but for C i do not, the correct answer is supposed to be
ECx=(2[tex]\rho[/tex]r/36[tex]E[/tex]0)
but i cannot get to it, where am i going wrong??
Hi Dell,
diagram below
my workings:
This expression is true, but remember that it applies when the point you are looking at is inside the sphere. (Notice that if you plot it out, it gets larger and larger as you move away from the center; this is true as long as you are inside the sphere, but once you move outside the sphere the electric field begins decreasing.)
But the field point for part c is outside the imaginary sphere. So what you need for part c is to find the electric field outside of a sphere (but with the formula still including the charge density of the sphere). Does this help?
i think so, can i take the sphere as if all its charge were in its centre and use Kq/r^2 for my field?
That sounds right (but when you rewrite it with the charge density you'll have to be sure to keep track of what the different R's mean). Do you get the answer?
yes thanks, worked perfectly
Glad to help!
  • · Replies 16 ·
