The true speed of Electric and Magnetic force.
The discussion revolves around the propagation speeds of electric and magnetic forces in an ideal circuit scenario, exploring theoretical aspects of circuit behavior without ohmic losses. Participants examine how these forces transmit in different configurations and materials, including coaxial cables and other conductors.
  • One participant questions the speed of electric force transmission around an ideal circuit and the propagation speed of the magnetic force generated by the current.
  • Another suggests introducing realism by considering a circular loop for the circuit layout.
  • A participant proposes examining a straight wire section to simplify the analysis.
  • Discussion includes insights from coaxial cable experiences, noting that signals travel at different speeds depending on the dielectric material, with some speeds approaching the speed of light in vacuum.
  • One participant mentions that magnetic flux travels at the speed of light where current exists, illustrating this with an analogy to supersonic aircraft and shock waves.
  • Another participant seeks information on velocity factors for various conductors, asserting that copper without insulation would transmit at the speed of light.
  • It is noted that the speed of light in coaxial cables is influenced by the dielectric material rather than the metal itself, with air as a dielectric allowing for speeds close to c.
  • A participant emphasizes the distinction between mathematical models and physical reality, discussing the complexities of calculating velocity factors in high-frequency scenarios.
Participants express differing views on the propagation speeds of electric and magnetic forces, with no consensus reached on the exact speeds in various configurations. The discussion remains open with multiple competing perspectives.
Limitations include the dependence on specific configurations and materials, as well as the complexities introduced by high-frequency effects and neighboring conductors, which may not be fully resolved in the discussion.
BrianConlee
To all the experts:
Ok, in this example, I'm going to have an "ideal" circuit with no ohmic losses, etc. just for ease of calculation...
The circuit is connected to a power source with it's own on/off switch.
I turn on the power source and...
1. How fast does the Electric Force transmit around the circuit?
2. How fast does the Magnetic force generated by the moving current propagate away from the wire?
I'm imagining that both are moving at either c, or close to that. In a perfect vaccuum, etc.
These answers will no doubt lead to future questions.
you need to introduce some realism to this ideal circuit.
A circular loop where the switch and power supply are along the circle would help.
hmmmm,
ok, what if we observe a small section of straight wire within a circuit. No resistors, capacitors or anything like that. Just say point a to point b.
Does that help?
In my experience with signals in coax cables, "instantaneous" signals in RG-8 travel about 8 inches per nsec. If the cable had no dielectric, then the signals would travel about 12 inches per nsec (speed of light) . If you have no well defined layout for the wires, the impedance (meaning sqrt(L/C) where L and C are the inductance and capacitance per unit length) is not well defined. The signal will reflect back to the source, and because there is no termination or ohmic losses, you are going to have the signal rerflecting back and forth (oscillating) for ever and for ever, except that the impedance of free space is 377 ohms...Is anyone out there listening?
Most RG-XX coax cables have a velocity factor of 0.659, with the exception of RG-62, having a vf of 0.84.
The magnetic flux travels at c where the current exists.
If you have 1000 feet of RG-59, and apply a signal to both conductor and shield, at 3nS there will be a slight magnetic field around the first 1.5 feet, moving outwards at 12 in/nsec, and no magnetic field the rest of the length.
If you've seen an image of a supersonic aircraft, looking at the compression of the air at the nose of the plane is "kinda" how the magnetic field precedes the electric current. The actual sizes/materials are wildly different though, as the airplane is the current moving at 0.6*c, and shock wave is the magnetic field moving at c.
This isn't normally a concern when dealing with frequencies most DIY/hobby people can build circuits for, with exception of very high speed logic on solderless breadboards. It is a huge design issue with circuit layout and PC Boards running at speeds where the wavelength of the signal is approaching the length of a trace. Routing a PC Board is a high order art/science so that, for example, all 64 bits arrive at the same time over a distance of 3 inches.
The actual velocity factor on fiberglass PC Boards is between 0.5 and 0.6.
Thank you Bipolar. That's the kinda answer I was looking for. Do you know where I can find these velocity factors for other conductors??
I believe Copper with no insulator is c right?
Thanks.
The speed of a light in a coaxial cable depends on the dielectric used; not the metal.
But yes, if you were to use a cable with air as a dielectric (air is very similar to vacuum in this case) the speed of light will of course be c. The dielectric in most cables is made from some sort of plastic, e.g. PTFE.
Remember, the math and reality of it NOT the same, just for visualization.
The air compressed in front of the plane would be the magnetic field in front of the current, since the magnetic field is traveling at c, and the current is traveling at some fraction of c, usually between 0.5 and 0.8. Two conductor cables are simulated by capacitance per foot and inductance per foot to approximate reality.
The actual equations for velocity factor are relatively straightforward, if you have the wavelength and measured parameters that aren't as easily obtained regarding the dielectric. This is further complicated by neighboring conductors, creating an electrical network at high frequencies.
DC current when turning on is a "high frequency" in the form of the leading edge of a square wave.
There are simplified "single wire" formulas on http://www.jenving.se/tables.htm#Formulas .
Again, with most circuits, the vf doesn't change the rest of the theory.
  • · Replies 20 ·
